05-20-2016, 08:39 PM | #1 |
How do I install outer window AD trim?
This question is for those who have put these together more than me. How do I get these outer trim pieces installed without bending them? If I recall, I had to flex them to get them out and they bent in the corners, which I had to hammer and dolly back straight before paint. How do I get them back in without bending them again?
Thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
05-20-2016, 10:27 PM | #2 |
Re: How do I install outer window AD trim?
You want the place the bottom in and gently fold the top ends in toward each other to create enough clearance to slide the top of the trim into place. Once in place you can extend the top ends outward so that the top trim fits evenly over in the corners....make sense. I tried to explain it the best I could. Take it slow and start with the bottom.
Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-21-2016, 07:43 AM | #3 |
I have never put these on, but have recently taken several doors apart. Have thought when I put them back on it would be easy to peel fresh paint off the door if you are not careful.
05-21-2016, 11:41 AM | #4 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
05-21-2016, 10:05 PM | #5 |
Thanks guys! I'll give it a shot in the next couple of days.
