Old 05-22-2016, 08:59 AM   #8
hatzie
Moderator
hatzie's Avatar
Re: Carter Carb Help
The 9635 & 9635S Competition AFB were Carter manufactured 650CFM Aluminum Four Barrel carbs with GM Linkage, Electric Choke, and Emissions Calibration. The 9635 is physically the same carb as the 9625 AFB with the addition of an EGR port to make it more emissions friendly.
The 9635SA is a 9635S made after the Carter bankruptcy... probably by Federal Mogul. I would guess that the original Carter rebuild parts will interchange. Metering rods and vacuum piston springs for some Carter one, two, and four barrel carbs can sometimes get a little dicey to find. The 9000 series should be easier because they are not 50 years old.
I took the easy route on one of my projects and don't regret it. I used a stock Chrysler Rochester Quadrajet and spreadbore manifold off an 80's Dodge W200 with a 7.4L to replace the squarebore Carter AVS 4638 on the B383 in my 1969 Polara 500. The metering rods and mating jets in the original 1969 Carter AVS were visibly worn out and close to impossible to find. The Rochester was much easier to rebuild, much easier on fuel, and isn't so cold blooded.
Since this is not an original piece I'd get a rebuilt Rochester and manifold or a new squarebore Holley or Edelbrock carb to replace it. The Holley and Edelbrock squarebore carbs will fit your existing manifold but you'll have to tune em.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
accelerator pump, carburetor, gasket, rebuild
