Closed Thread
Old 05-22-2016, 11:33 AM   #2326
TJ's Chevy
TJ's Chevy's Avatar
Re: What did you do to your truck today part III
Modified the magnum intake for my 305 V6.
TJ's Chevy is offline
Old 05-22-2016, 12:17 PM   #2327
OldChevy61
OldChevy61's Avatar
Got my doors painted Friday and planned on hanging yesterday. My back said no. Got them hung this morning.
OldChevy61 is offline
Old 05-22-2016, 01:14 PM   #2328
PORKY
PORKY's Avatar
Nice job! Makes me wished I would have kept mine that color.
PORKY is offline
Old 05-22-2016, 03:50 PM   #2329
earl84
So, so nice, Oldchevy61. Absolutely love the colors.
earl84 is offline
Old 05-22-2016, 04:18 PM   #2330
Grizz1963
Grizz1963's Avatar
Martins engine stand came back and now my transmission is mounted on it, awaiting its service, shifting kit and new seals.
We also got the truck back on four wheels, new steering parts fitted, and the drop link etc refitted.
One more bit of cleverness from Martins day job, which is always about checking and double checking and legal culpability Is to mark your nuts with red paint.
So I went into the house and asked Nicola for some red nail polish.......
Every nut and split pin fitted and torqued down was marked so that I can see where things have been done.
HAPPY HAPPY HAPPY..........!!!
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 05-22-2016, 07:42 PM   #2331
robber grin
Managed to install the home made shroud today.
robber grin is offline
Old 05-22-2016, 08:47 PM   #2332
TJ's Chevy
TJ's Chevy's Avatar
Installed my opened up magnum intake and took the truck for a test run...Man does it pull good!
Old 05-23-2016, 11:46 AM   #2333
jayoldschool
Moderator
Robber, your fan is too deep in the shroud. It will work more efficiently if the blades are only partly covered. Nice work, though!
jayoldschool is offline
Old 05-23-2016, 07:00 PM   #2334
robber grin
It's @ half in and half out and I hope it works as is - if not I'll pull it off and sand it down some in depth. Thanks
On a happier note it's in for dual exhaust and final set-up / inspection
Old 05-23-2016, 07:54 PM   #2335
jayoldschool
Moderator
Ok, you're good then! The angle of the pic makes it seem that the fan is all inside the shroud.
Old 05-24-2016, 09:28 AM   #2336
Willie 66
Got (most of) the front end put back on. One step closer to the road.
Willie 66 is offline
Old 05-28-2016, 06:45 AM   #2337
robber grin
Truck is in the shop for dual exhaust and final touches.
Yesterday Dwayne got the two inch Stainless routed all the way back to the rear bumper.
I had two nifty little heat shields bent at J/T Welding and installed those.
Engine wiring is done other than hot for choke and alternator conversion to ignition.
Old 05-28-2016, 02:59 PM   #2338
chevy2tom
chevy2tom's Avatar
Getting the rebuilt 200 4r ready to install
chevy2tom is offline
Old 05-28-2016, 07:06 PM   #2339
The Rocknrod
Moderator
The Rocknrod's Avatar
Thats nice.
Post some pics of the chassis and such with the 200R4 in it.
The Rocknrod is offline
Old 05-28-2016, 08:02 PM   #2340
Backpayne
Added some stock steelies with new thin whitewalls. Tires are 235/75/15.
Backpayne is offline
Old 05-29-2016, 12:39 PM   #2341
wcorbett
More like this week.... Its been a good one though. Started with some wiring clean up. Wired in a couple of relays to provide full batt voltage to the starter solenoid and the HEI distributor. After 56 years, the under dash wiring is both aged and been altered some, so there's no guarantee that there isn't voltage loss through the system. Short of a complete re-wire/new wiring harness, this is the easiest way to ensure full system voltage to both of these vital parts. Also, added a 0 gauge cable from the battery to the starter, so that pretty well maxes out the available voltage.
Then added a front sway bar from a 67-72 truck to the front end, and then a pair of Bilstein shocks to top it off. The improvement to handling is night and day, and really makes the truck much more fun, and safe, to drive. Especially on the curvy roads here in the Sierra foothills.
Like I said, a good week in the life of a truck that been static for a long time.
wcorbett is offline
Old 05-29-2016, 04:51 PM   #2342
mjh1965
mjh1965's Avatar
This afternoon I got some TRUCK TIME ..........
First I pushed it out of the garage (these new wheels are great on the trolley thanks Rian)
The first job was to remove the old sound deadening pads
Wow it's amazing the difference between two cabs of the same age .
All the sound deadening pads removed
Next job was to remove the old dash . The radio was fitted by a blind man with a chainsaw I think
Dash all removed
New dash in place that I removed from my old cab
After that job was done I filled in the gas filler hole .
Next job will be to fill in the hole in the transmission hump , and then remove and clean up the brackets for the gas tank .
It's great to be working back on the truck , and not a bad afternoons work .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 05-29-2016, 05:53 PM   #2343
TJ's Chevy
TJ's Chevy's Avatar
Took the dash apart on my GMC to see why my fuel gauge wasn't working properly....guess the nuts were a bit loose as it's working good now!
Cleaned up the lenses a bit and replaced a burnt out bulb.
Old 05-29-2016, 05:57 PM   #2344
65chevysub
65chevysub's Avatar
Got some minor rust issues wire brushed on the floor of my Suburban. My cowl vents were leaking, and ruined my carpet but also created some rust on the drivers side, but didn't go all the way through(whewww!) Will get a gallon of gloss black Rustoleum next week and get the floor painted just in time for our 100+ temps.
65chevysub is offline
Old 05-31-2016, 05:51 PM   #2345
Chevy Apache
Hi all after many months of looking at a dent in my bonnet for the last year or so.
Enough is enough had to sort it.
Now time to find some inserts for my indicaters.
Chevy Apache is offline
Old 05-31-2016, 06:01 PM   #2346
robber grin
After seeing the dual exhaust roughed in, while Dwayne is finishing up I decided to fab some splash pans to close the gap between the rear bumper and the bed.
This was a factory thing for the 63-66 trucks but to my knowledge didn't happen till at least 63... anyway it just happened for my 62.
Bent some 24" x 6" 20 gauge tin from the builders supply into pans and drilled for mounting hardware.
Should work nicely
Old 06-01-2016, 12:14 PM   #2347
robber grin
Dwayne just informed me it RUNS
no knocks pings taps or leaks
Alternator light stays on once you connect the battery ??
Turn Signal indication on dash stays on ??
One back up light works the other doesn't
Front brakes locked on - thinking proportioning valve might be bad
Welding up exhaust
Old 06-01-2016, 07:33 PM   #2348
Hugh in NC
Hugh in NC's Avatar
I got my new Champion American Eagle radiator installed. Only problem I had was the bottom of the new radiator was the same thickness as the top. The bottom of the original radiator was 1/2 inch smaller than the top tank. I found some wider brackets at the local junk yard, replaced the smaller ones and the radiator fit right in place. I also replaced a homemade looking fan guard/shroud with a new chrome one.
Hugh in NC is offline
Old 06-01-2016, 08:19 PM   #2349
Don't forget your seals around the top front and the sides of the radiator and the support. Unless if there are any gaps it will let the air bypass the radiator and not cool as efficently.
I made my side seals and front top seal, but you can see about what the 3rd pciture has for a factory (if all the pieces were still on it) looks like. It makes a tremdous difference on cooling ability, especially on the highway or if you have AC.
Palf70Step is offline
Old 06-01-2016, 08:19 PM   #2350
canadian_diesel1964
Started the bed assembly on the micro buck build
canadian_diesel1964 is offline
Closed Thread
