![]() Join Date: Jan 2015
Intellitronix Gauges Install
Hello, I am looking for some guidance on how to install these Intellitronix gauges?
Thanks |
Collector of Projects
Re: Intellitronix Gauges Install
https://youtu.be/V6Khujsqt7Y
Midway through the video is a good idea of how it was done.... You might want to fill out your profile, tell us what vehicle you're talking about and maybe include some pictures of what you're working with.... |
#3 | |
http://www.ebay.com/itm/67-72-Chevy-...8b942c&vxp=mtr |
So no instructions? I would email Intellitronix and see if they can send you some...
![]() Join Date: Mar 2004
Or ask Stacey David
Look up member Johnnyfever. In his albums, he has the instructions.
The gauges came with instructions but I am still having issues. I will see if I can find Johnnyfever's instructions. Thanks Gents
Remember, we need pics!!!
Good luck with the install |
![]() Join Date: Sep 2011
Bump......included instructions leave a bit to be assumed........
1967 C10 SWB Owner - Rustbelt Restorations |
hey, i just bought this set up as well. i have a conversion to a 94 drive train. anyone know what wire from the ecm i hook up to the speedo. i tried the brown and drk blue wire in the blue side connector. the blue didnt register any speed and the bwon said i was doing over 160mph when i was barely crawling
The speedo wire hooks up to the supplied VSS in the gauge kit.
so i have to replace the stock sensor? the intrusctions said if vehicle already has a speed sensor to hook up to the vss wire. from all the wiring diagrams i have found online it would seem to be either the dark blue or brown wire from the speed sensor to the ecm
#15 |
My instructions don't say anything about an existing vss. Mine says disconnect the mechanical speedo cable and install the supplied vss. Instructions say to wire it to the white wire on the vss.
#16 | |
For vehicles which have a vehicle speed signal from a transmission sensor or ECM, tap into the VSS wire (Consult a vehicle service manual or wiring diagram to determine correct wire color) and connect it to the WHITE speed sending wire from the digital dash. If your car is equipped with an electronic transmission then there will be an electronic vehicle sender with either 2 or 3 wires coming off of it. |
#17 |
There seems to be a lot of variations in the instructions because the colors my instructions said didn't match to the panel exactly. My manual for a 94 shows the wires going to the vss should be red/black and dark blue/white out of the ecm. They are out of ports f2 and f3 on the ecm. One should be vss power and the other would be the signal. Test to see which one has switched power and then tap into the other one. It's hard without knowing exactly how your wiring is
#18 | |
#19 |
It doesn't say what plug. Every wire is labeled with a letter and number on the plug itself
