Closed Thread
Old 05-20-2016, 12:53 AM   #3726
midniteblues
midniteblues's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by palallin View Post
Midniteblues: THAT is a pretty Mouse!
Thanks man ....sometimes I try to do good.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 05-20-2016, 02:34 AM   #3727
mike16
bought a cap rotor plugs some fuel line and an air filter..... oh.... and added another qt of oil
mike16 is offline
Old 05-20-2016, 10:13 AM   #3728
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Wow that grille looks great ! .
I bought a GM Heritage grille , no way the body man could make it fit back on went the old one .
I don't think those headers were ' ruined ' .
If you're not going to use the choke stove you'll have to put a brass plug in the hole so it doesn't puff soot all over your lovely engine .
My truck is mostly stock but I searched until I found some long oil and ATF dipsticks from a G Series van , now I don't have to reach in at all to check my oil and tranny .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 05-20-2016, 05:23 PM   #3729
Rich69shortfleet
Was going to order some Digi-Tails LED taillights but their website if FUBAR.
Rich69shortfleet is offline
Old 05-20-2016, 10:38 PM   #3730
SoCoC10
SoCoC10's Avatar
Nothi'n like fresh carpet.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline
Old 05-20-2016, 11:02 PM   #3731
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Nice carpet ! .
I'm thinking of using green carpet to match the paint....
-Nate
Geezer
VWNate1 is offline
Old 05-21-2016, 12:36 AM   #3732
dmjlambert
dmjlambert's Avatar
You guys are way ahead of me. Today I flapped what was left of the rotten carpet out of the way and pried the rust-locked connector loose from the old decrepit high/low beam switch as it fell apart in my hands. Worked loose the screws, cleaned them up, and put in a brand new switch. I love it! Works great! My first use of a #3 phillips screwdriver in a long time.
dmjlambert is offline
Old 05-21-2016, 04:01 PM   #3733
firedemon
tried to sand blast the bed today didn't work out going to have to try some chemical first . like the look of the flat black though
firedemon is offline
Old 05-21-2016, 04:23 PM   #3734
66clow
66clow's Avatar
Finally got the truck road worthy. First fill up, got it weighed so I can get my tags, needed in California, first wash, and made the hour and half ride home yeah!
66clow is offline
Old 05-23-2016, 12:11 AM   #3735
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Pulled my retract seat belts. They sure cleaned up nicely. Other than one faint scratch in a boot ("pictured" on right) the boots are like new. The interior on these trucks were sure made well. Cloth seats excluded, IMO.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 05-23-2016, 01:22 PM   #3736
70STOVEBOLT
70STOVEBOLT's Avatar
Not today, but I forgot to post when I did this. Fabbed a bracket for my fuel psi regulator.
Gotta remove it for paint yet...
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 05-23-2016, 01:35 PM   #3737
Rich69shortfleet
Bought LED taillights, side markers and front park/turn lamps.
Old 05-23-2016, 01:35 PM   #3738
OregonNed
OregonNed's Avatar
That looks great! I want to find a regulator for my carb- may I ask what you went with? Thank you
OregonNed is offline
Old 05-23-2016, 01:42 PM   #3739
70STOVEBOLT
I used a Mallory 4207 that I bought from member Madmartigan. You can get them thru Summit, Jegs, etc. I used the Eddy fuel line kit with filter, then used a 45 degree flare female swivel - to - 3/8 male pipe adapter, then a brass 3/8 pipe street elbow. I made a new fuel line to go from the mechanical fuel pump to the elbow coming out of the regulator.
I used a Holley non liquid-filled gauge, as I read the liquid filled ones are not accurate once the underhood temps come up. I have about $100 in the setup, but I got a good deal on the line kit (Amazon, it was a returned item so it was discounted) and regulator. The bracket was just a piece of scrap steel that I cut with a bandsaw and rounded the edges with a bench grinder, then bent it in a vice with a soft hammer. I made a template out of paperboard beforehand and it fit perfectly.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 05-23-2016, 02:49 PM   #3740
tommy3horse
tommy3horse's Avatar
Over the weekend, I noticed a slight vibration when applying the brakes, seeming like the rears. This morning I pulled the drums and found the shoes needed replaced along with a turn on the brake lathe. Headed to pick-up the drums now, was a lot easier that I expected, like all the other drum brakes I have ever done over the years.
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline
Old 05-23-2016, 03:12 PM   #3741
88Stanger
88Stanger's Avatar
Originally Posted by Fat Lip Fab View Post
Dimpled my door panels over the weekend.
that is a cool idea!
88Stanger is offline
Old 05-23-2016, 03:15 PM   #3742
tdangle
tdangle's Avatar
At some point the vac canister must have broken thru the mounting on the side of the AC box under the hood. Dad just covered the huge holes with gray duct tape and remounted it lower which also got broken at some point. I cut and mounted a plate to cover and seal the holes and remounted the new vacuum ball.
At some point in the future I may try to find a new AC box half, but for now it works.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 05-23-2016, 04:23 PM   #3743
OregonNed
OregonNed's Avatar
Awesome. Thanks for sharing the information.
Old 05-23-2016, 05:02 PM   #3744
70STOVEBOLT
Not a problem, glad to help.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 05-23-2016, 05:41 PM   #3745
slo72c10
New seats started interior
slo72c10 is offline
Old 05-23-2016, 07:43 PM   #3746
Rich69shortfleet
Are those Procar Pro90 lowback seats? If so, how do you like them? I was toying with the idea of installing those in my truck. I can get them at Speedway Motors which is local to me so I'd save a ton on shipping.
Old 05-23-2016, 08:04 PM   #3747
ole dollor
ole dollor's Avatar
those look nice, love me some bucket seats .....
ole dollor is offline
Old 05-23-2016, 09:24 PM   #3748
chipmyers
Broke it
chipmyers is offline
Old 05-23-2016, 09:36 PM   #3749
firedemon
owch
Old 05-23-2016, 11:03 PM   #3750
66clow
66clow's Avatar
Finished the crazy dealings with California DMV to get my out of state truck registered and got my tags.
66clow is offline
Closed Thread
