Closed Thread
Old 05-23-2016, 11:13 PM   #3751
Metaldoc
Metaldoc's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 66clow View Post
Finished the crazy dealings with California DMV to get my out of state truck registered and got my tags.
Is it just me or your headlights in wrong why are crooked ?
Metaldoc is offline
Old 05-23-2016, 11:36 PM   #3752
66clow
66clow's Avatar
Lol you are correct I was tackling the major things first. I'm roadworthy now. Was like that when I bought it. It's on the list. Actually looks like it is looking into the camera.
66clow is offline
Old 05-24-2016, 12:17 AM   #3753
OregonNed
OregonNed's Avatar
Priming and sanding parts
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 05-24-2016, 03:42 AM   #3754
summitflier
summitflier's Avatar
Spar Urethane on the wood, and painted the tailgate.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline
Old 05-24-2016, 07:59 AM   #3755
70STOVEBOLT
70STOVEBOLT's Avatar
What color is your truck? I really like that blue.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 05-24-2016, 08:42 AM   #3756
OregonNed
OregonNed's Avatar
I'm told bright blue metallic
Old 05-24-2016, 08:44 AM   #3757
70STOVEBOLT
Ok, thank you.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 05-24-2016, 10:40 PM   #3758
OregonNed
OregonNed's Avatar
Came home from work this afternoon and did some more sanding inside my box. It as a bit rough inside so we are going to smooth and repaint as a welcome home to the new wood bed. Here is one inner bedside I am working on.
Old 05-24-2016, 10:50 PM   #3759
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Had to take the cover off, charge the battery, and start her up as far as operating temperature before she went back to bed....Too many
"better-do-'ems" today...
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 05-24-2016, 10:56 PM   #3760
66clow
66clow's Avatar
Corrected my head lamps , found out the po had the headlamp buckets switched. There is a right and a left side to them. Identified with a L and R.
66clow is offline
Old 05-24-2016, 10:58 PM   #3761
mike16
i replaced the rubber fuel lines on my truck
I used Gojo lanolin hand cleaner on all the rubber bits under my truck.
I scraped about four lbs of grease sand and rocks off of my trucks frame and drivetrain.
I sucked about 2 gallons of bad gas out of my trucks fuel tank
mike16 is offline
Old 05-24-2016, 11:15 PM   #3762
midniteblues
midniteblues's Avatar
Cleaned up the more of the grime today. This is the third time around with the scraper, p washer and gunk degreaser.
I almost feel bad about washing away the years of frame saving greasy tar like goop.
Lying in the wet greasy grass too blast the underneath isn't any fun. But I did reveal a Chelsea plate on the pto.
Think im Almost there MAYBE one more time around.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 05-25-2016, 12:46 AM   #3763
mechanic350
mechanic350's Avatar
made a custom gage bracket for my new auto meter gauges.
1972 Chevrolet swb fleet side. - SOLD
2018 Toyota Tacoma but hunting for another C10
Link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=607303
Instagram: https://www.instagram.com/72c10shortbox/?hl=en
mechanic350 is offline
Old 05-25-2016, 01:02 AM   #3764
heathbirkendahl
So clean!!! Nice work.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 05-25-2016, 03:25 PM   #3765
Rich69shortfleet
I ordered a factory style tach conversion for the instrument cluster, a new bezel, a door jamb switch harness, courtesy light harness, a new engine harness with HEI support built in and a new temp sending sensor. The temp gauge in my cluster has never really read the temps quite right, always reads low. I think this is because the sending unit is for a 1976 engine/truck (came with the sb400 I installed). I'm guessing 1976 gauges were calibrated differently. I hope to be buying new bucket seats soon as well.
Rich69shortfleet is offline
Old 05-25-2016, 06:22 PM   #3766
C10hacker
Talking Re: What did you do to your truck today? Chapter II
Put some advanced safety feature in the truck. Out with the bench seat in with the power Sebring Convertible seats($50 half off sale at the junkyard). I also picked up a f-250 jumpseat off craigslist for $40 that needs to go in. I cant find a pic of the bench but oh well.
C10hacker is offline
Old 05-25-2016, 08:24 PM   #3767
flashed
Those seats look good.
flashed is offline
Old 05-25-2016, 08:30 PM   #3768
dspurr1
new c10 project, leave the way it is or full restoration?? Ideas
dspurr1 is offline
Old 05-25-2016, 09:04 PM   #3769
C10hacker
Thanks, they were a steal. I had to pull apart the passenger side seatbelt and rebuild it because it was stuck due to the accident. But everything went smooth, just about 10 minutes of my time and fiddling with the internals. I now need to figure out how to make a little extra room for my legs. I am 6ft and I lost about 2 inches of room. Next step is disc brakes and then getting parts for the LS swap to fit in the truck. The donor silverado is waiting patiently to be torn apart.
Old 05-25-2016, 09:12 PM   #3770
RINC
RINC's Avatar
Leave it.
Drive it.
Enjoy it.
Chris
'69 C-20
'04 Jeep TJ
RINC is offline
Old 05-26-2016, 12:26 AM   #3771
heathbirkendahl
Ditched the chrome alternator and painted the billet bracket.
Old 05-26-2016, 10:37 AM   #3772
snipescastle2
snipescastle2's Avatar
I am almost finished with my Electric Vacuum Pump install, just have to wire up the relay and test it out..... I also finished wiring up the electric power window crank switches on the modded window regulators, (I had to move the crank stub forward 3/4" forward to align with the door panel holes) since I was at it, I cleaned up the wiring and drilled the holes to pass the wiring through the hinge pillar and door, now to install some conduits, rubber or what ever works, I think the braided steel ones I made are too rigid, they walk the rubber grommets out of the holes I cut, oh well, something that won't be seen too much any way.
I also finished my Van tilt steering column the other day, and once I get my power windows in, I can finish up the weather strips/vent windows, etc.. and start driving this bad boy! Pictures to follow!
Have a good one!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline
Old 05-26-2016, 11:56 AM   #3773
lilred2
lilred2's Avatar
Started getting my new Boyd tank installed and adjusted the valves.
lilred2 is offline
Old 05-26-2016, 09:18 PM   #3774
firedemon
got the speakers out from under the seat and the kick panels in what a difference . going to have to do something with the interior doors when grumpy new door panels get here that sky blue aint going to cut it . originally was planning on pulling the doors and stripping them out when I get ready to paint the outside so I didn't paint them when I did the rest but now with all the rest mostly finished its going to bother me that they look so bad
firedemon is offline
Old 05-27-2016, 07:49 PM   #3775
matthamby
Just dropped off my seat to have it patched. 2006 Silverado seats, driver's side has a hole in the fabric and into the foam, he said it may be done tomorrow, I hope so!
matthamby is offline
Closed Thread
