![]() Join Date: Feb 2011
clunking
I have an 06 silverado1500. Every time I hit the tiniest bump there is a clunking sound in the steering wheel. I took it to firestone and they said idler arm. I took it to les schwab and they found that the passenger side wire that gos to the electric shock was broken off. schwab said that it could either be the electric shock or the steering box. My question is would the shock make a clunking noise just because of the electrical wire being not connected?
Re: clunking
Could be the Intermediate Steering Shaft rattling/clunking.
To be sure...... Tie the Steering Wheel with the Seat Belt so it cant move & break the Clock Spring. Under the Hood where the steering shaft exits the firewall, There will be a 15mm headed bolt, Remove it. Separate the Intermediate & Lower Steering Shafts by pushing the Intermediate shaft toward the rear of the truck. Work the shaft in & out a good 20 times, This will redistribute the Grease in the Intermediate Steering shaft. Reassemble the shafts & test drive, If the noise is now gone....You found your issue, It WILL come back in 5-10,000 miles. You have a few options....Redo it every time the noise comes back, Install a grease Zerk in the shaft so you can re-grease with a gun, Or buy a replacement shaft from Borgeson http://www.borgeson.com/xcart/produc...ctid=1451&cat= Don't bother buying a GM one. |
Re: clunking
Thanks for the reply! I went to the dealership today. They had no clue what it could be, until an old guy mechanic was walking by and said almost exactly what you just said. I'm going to give it a try this weekend.
Re: clunking
Yep do what clinebarger said ,that's what I did and no more clunk
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
Re: clunking
I 2nd Clingbanger's solution. Been there, done that, actually need to do it now, again.
'67 Chevy Longbed Fleetside - Daily Driver(For Now) '72 Cheyene Longbed Fleetside-Daily Driver Best Towing Service |
Re: clunking
The dealership replaced the steering shaft, since I had no time. Steering is completely quiet now, thanks Guys
Re: clunking
This happened to me and my (then) new 2004 Silverado. Took it in once and the problem came back a short while later. Second time to the dealer, they fixed it for good. Not sure what they did, but that was 12 years and 80K miles ago.
#8 | ||
"I ain't nobody, dork."
Re: clunking
Same deal for '06 K2500HD? I have had a rattle in the front for some time now. I thought it was the disc brake calipers, but now I'm thinking it might be the steering shaft.
Gary
![]() Join Date: Sep 2005
Re: clunking
where is the best place to nistall a grease fitting to lube the shaft every some offten
Re: clunking
Does anyone have a pic of a Zerk installed in the shaft?
Re: clunking
I've owned 4 of these year trucks over the past 10 years. ALL of them did it at some point. I've always done the "remove the 15 bolt and stroke it" fix on all of them about once a year. Matter of fact, just did this exact thing to my Silverado SS daily driver on Sunday night.
It is a KNOWN issue with GM trucks, but GM has pretty much instructed dealerships to "play dumb" when it comes to it. It is not a safety issue, so they don't want to spend the money to issue a recall. |
Re: clunking
I removed the "center" 1 . 5mm bolt but nothing moves.
Is it the upper or lower shaft that is supposed to move, the one with the boot that goes to the R&P?
Re: clunking
Re: clunking
Well I will work a bit harder on it this time !
#15 |
Re: clunking
#16 |
Re: clunking
So just in case I will put a index mark on the two shafts!
#17 |
![]() Join Date: Jun 2013
Re: clunking
I just bought an 06 and have the same issue...looks like I have a new plan for the weekend.
