C-Notch - CPP & Stereo's tricks
Getting ready to c-notch my 71' with a CPP kit. Anyone have pics then can share?
Share your stereo pics and secrets! (If you don't mind please..LOL) Thanks, Heath
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
Re: C-Notch - CPP & Stereo's tricks
Check out my build thread below my signature. Put the CPP Cnotch kit in as well as a pretty nice stereo. May have to dig through several pages but it's there.
Thanks, Casey ![]() The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
I traced out the notch onto a piece of cardboard then laid it against the frame to use as a template. I bolted it as well as welded it just in case.
Mike |
#4 | |
Could you have done it without removing the bed?
#5 | |
Nice build buddy. Well done!!
I removed the fuel tank from the cab and built a box for 3 sealed 10's.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
My sub box
That's gonna thump!
Custom door panels? Did you have to cut the door?
They were already cut, I have 6.5"mid range drivers in the doors and tweeters in pods on top of the dash (not really visible) and 4" drivers under the factory center speaker hole. Yes it sounds pretty good. I'm a bass hound. 9 speakers in that cab.
Yes. It could have been installed with the bed on.
Mike |
Thanks. Lots of work.
