Old 05-20-2016, 02:39 PM   #51
GoPokes72
GoPokes72's Avatar
Re: Gertie, the 72 c10 Highlander
Originally Posted by 68Gold/white View Post
Look'n Good in the neighborhood!!!
Thanks, 68Gold/white!!
GoPokes72 is offline   Reply With Quote
Old 05-20-2016, 02:50 PM   #52
jus2qwk
jus2qwk's Avatar
Originally Posted by GoPokes72 View Post
So I finally ordered my Vintage Air and it showed up the other day! I ordered it from Laid Back Recreations... I've got to say they are top notch! Sarah was awesome and super helpful! I also order my heater control panel from CJ Designs, an awesome piece. I would highly recommend them both.
thanks for the shout out! I'm glad you like the panel.
Corey Jones Designs
CoreyJonesDesigns on instagram
Ole Silver- 1967 stepside
http://www.hotrod.com/articles/1103c...chevrolet-c10/
http://67-72chevytrucks.com/vboard/s...d.php?t=598758
jus2qwk is offline   Reply With Quote
Old 05-20-2016, 03:07 PM   #53
GoPokes72
GoPokes72's Avatar
I got my new buckets mounted. Also got my new ACC carpet from Rockauto.... and a new ForeverSharp steering wheel! About ready to start getting the interior wrapped up so I can get my vintage air installed before the Oklahoma heat shows up!
Old 05-20-2016, 03:13 PM   #54
GoPokes72
GoPokes72's Avatar
No problem man, it's awesome! I'll hopefully be installing it soon.
Old 05-20-2016, 05:38 PM   #55
MMcMasters
MMcMasters's Avatar
I really dig the color combination.
Mike
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 05-25-2016, 04:16 PM   #56
GoPokes72
GoPokes72's Avatar
Mike
Thanks, Mike! Its really grown on me, I cant imagine it any other color now. Your 67 is looking great by the way! Excited to see that one finished!
Old 05-25-2016, 04:20 PM   #57
GoPokes72
GoPokes72's Avatar
Got my new wheels and tires on!
Old 05-25-2016, 04:45 PM   #58
layinrocker65
layinrocker65's Avatar
Are those 255/70r15s?
Looks great!
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 05-26-2016, 02:34 PM   #59
GoPokes72
GoPokes72's Avatar
Looks great!
Thanks, layinrocker65! They're 255/60r15s.
Old 05-27-2016, 07:28 AM   #60
Aus69c20
Aus69c20's Avatar
Love this build. Your getting after it and inspiring me to get moving on the jobs that need doing on my truck. Top job.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 11-22-2016, 05:49 PM   #61
GoPokes72
GoPokes72's Avatar
Thanks, Aus69c20!
Old 11-22-2016, 05:53 PM   #62
GoPokes72
GoPokes72's Avatar
Well this has been a slow process, as promised. I unfortunately did not beat the heat, so my project was on hold for most of the summer. But summer is over and work has resumed. I have still been working on the interior and getting the vintage air installed. Like most know a can of worms can quickly be opened, but a little harder to shut!
Worked quite a bit on the floor, getting as much of the rust as i could out without actually cutting anything out. I also work on sealing up the cab the best I could. The goal for now is to keep the inside dry!
Some before pics...
Old 11-22-2016, 06:07 PM   #63
GoPokes72
GoPokes72's Avatar
Figured now was a good time to get my cab mounts replaced. I went with poly for longevity. I also had to cut out the spot welds on the bolts. I bought a Dremel to get into the small depression more easily. (Such an awesome tool! )
Old 11-22-2016, 06:35 PM   #64
GoPokes72
GoPokes72's Avatar
I used a combination of metal sealer, rubberized coating, and undercoating to seal any place that water was getting in. I then undercoated the entire floor and put down Fatmat.
Old 11-22-2016, 06:41 PM   #65
GoPokes72
GoPokes72's Avatar
More pics...
Old 11-22-2016, 10:57 PM   #66
rustytruck50
rustytruck50's Avatar
Nice job on the build...I'm taking notes for my '72
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 11-23-2016, 10:32 AM   #67
Hart_Rod
Hart_Rod's Avatar
Nice job
Hart_Rod is offline   Reply With Quote
Old 11-23-2016, 03:00 PM   #68
knomadd
knomadd's Avatar
Keep up the good work, it's looking good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 12-21-2016, 05:36 PM   #69
GoPokes72
GoPokes72's Avatar
Originally Posted by Hart_Rod View Post
Nice job
Guys, appreciate the encouraging words!
Old 12-21-2016, 05:47 PM   #70
GoPokes72
GoPokes72's Avatar
A few more pics of the interior... got the evaporator unit mounted under the dash and the duct work run. Also temporarily mounted my control panel.
Old 12-21-2016, 06:31 PM   #71
GoPokes72
GoPokes72's Avatar
Decided to go ahead and pull apart the front end so i could access everything more easily as well as clean up a bit. Here are some progress pics...
Old 12-21-2016, 06:44 PM   #72
GoPokes72
GoPokes72's Avatar
Had to do some rust repair work to my core support. Welded in a patch piece, cleaned it up, then spayed with undercoating. I then clean the whole piece and sprayed it with black.
Old 12-21-2016, 06:58 PM   #73
GoPokes72
GoPokes72's Avatar
Cleaned up my radiator. Fixed as may of the bent fins as I could and sprayed it with some high heat paint.
Old 12-21-2016, 07:06 PM   #74
GoPokes72
GoPokes72's Avatar
Also finished getting the Vintage Air installed. All I lack is getting everything wired up...
Old 08-16-2017, 06:35 PM   #75
GoPokes72
GoPokes72's Avatar
Its been awhile since my last post so I figure its time for an update. I worked on getting my front end put back together after I roughly straightened out my drive side fender. Wasn't looking for anything perfect just wanted to knock the dent out.
