Old 05-25-2016, 10:35 PM   #1
rigid
2000 fuel gauge or sending unit problem ?
2000 suburban . Had a new fuel pump module , which includes sending unit replaced at GM dealership lifetime warranty if done at the dealer . less than a year later gauge starts dropping and reading empty . Does this a few times and has been like that since . How do I determine if it is the gauge or the sending unit ?
Stealership and Gm say the new sending unit was not the pump so it is not covered . Their contention was that the pump still works .
Thank you
rigid is offline   Reply With Quote
Old 05-26-2016, 03:57 PM   #2
truckdude239
truckdude239's Avatar
Re: 2000 fuel gauge or sending unit problem ?
way i look it it is the sending unit is part fo the pump so should be covered never heard of them giving a lifetime warranty though
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 05-26-2016, 11:47 PM   #3
rigid
At the time we were on vacation towing a camper . Made it to a dealership sputtering along for 12 miles . It died for good in the lot while I was inside talking to them . I knew it had gotten a new before we bought it . They ask if it was a gm pump because it would have a lifetime warranty . I called previous owner and my luck it was not .
$1400 dollars later I had a new GM pump module and a lifetime warranty that does not cover the sending unit apparently . Gm said they would back the pump , but not sending unit .
