Old 05-27-2016, 01:10 AM   #1
c10 custom
blowing heat/ac fuse
Hello everybody i am working on a 1984 chev truck and the heat/ac fuse keeps blowing when you put the fan on high speed ? And the Oil Pressure Gauge stays pegged over to the right ? Any help on this would be greatly appreciated thank you
c10 custom is offline   Reply With Quote
Old 05-27-2016, 05:18 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: blowing heat/ac fuse
Download the 1984 wiring diagrams from the manual link in my signature. Option C60 (AC) is the bottom left panel of the right hand block of PDF page 14.
The HI setting doesn't power the fan directly it closes the contacts on a relay on the AC housing in the engine bay.
Either the orange wire from the switch to the relay coil is damaged and shorting or the relay itself is shorting internally. Unplug the switch and relay then ohm the orange wire to a good ground... the meter should read ∞ ( the same as unconnected meter probes ) if it reads anything else the wire is damaged.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
