Removing Aftermarket Trailer Brake Unit
The PO installed an under-dash mounted trailer brake assembly which I want to remove. It has a hard line connection to the back port on the proportioning valve which will need to come off. The trailer brake add-on 'T' screws into the prop valve, then the original line screws into that 'T'. I've already installed new front pads/calipers, rear shoes/cylinders and bled the entire system with new fluid and have great pedal.
Since the extra connector is right at the proportioning valve, will I need to worry about getting air into the valve and/or master cylinder or will I just need to re-bleed the system and be done? It looks like the back port may go to the rear wheels only so would I be able to just bleed the rear wheel cylinders or will I end up with air in both front and back? When I pull the fitting out of the prop valve, is that an open path for the master cylinder to drain or is there a check valve somewhere in the circuit that would keep it from free flowing? Sorry for so many questions, but being what brings me to a necessary halt I want to get the brakes back to full function. Thanks. |
#2 | |
![]() Join Date: Feb 2010
Re: Removing Aftermarket Trailer Brake Unit
Keith
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
the rear portion of the mastercylinder is the primary side. it goes to the front brakes,
![]() Join Date: Mar 2003
#5 | |
p.s. Fellow geetar guy |
