Old 05-27-2016, 03:22 PM   #1
BrianG
BrianG's Avatar
How many Amps through the temp sender circuit
Hello, I was hoping that some one has already done the research on this and knows what the amperage running through the temperature sending unit circuit is. I added an inline resistor (near the dash) to get my gauge to read correctly with the sending unit that I am using (3/8 fitting instead of standard 1/2). I have it dialed in finally, but wanted to make sure that I'm not going to burn my truck down. I have a 3/4 Watt variable resistor in-line. It is a Cermet style resistor. Anyone have any idea if this will be sufficient or is a potential issue?
BrianG is offline   Reply With Quote
Old 05-27-2016, 05:51 PM   #2
Wrenchbender Ret
Re: How many Amps through the temp sender circuit
The temp gauge draws a very small amount of current. It will not burn your truck down. If there is a direct short you have a fuse in the inst. circuit that will blow unless it the wireing has been cobbled .
Wrenchbender Ret is offline   Reply With Quote
Old 05-27-2016, 11:11 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Ease your mind.
Name:  temp gauge.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-27-2016, 11:14 PM   #4
70cst
70cst's Avatar
Not sure if this will help but ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-31-2016, 10:06 AM   #5
BrianG
BrianG's Avatar
Originally Posted by VetteVet View Post
Ease your mind.
Attachment 1537376
Thanks!, I guess this does ease my mind. I set mine up like the option two in your illustrations. I couldn't seem to get it to work right with the first option, although, I don't really see why it wouldn't have. Maybe I just wasn't patient enough.
