#276 |
Re: My 83' Crew Cab Dually project
Tan! I'm switching my interior over to tan. I like the door panels is that just standard suede fabric or backed with a foam or padding? I got a few yards of foam backed suede for my headliner. I'd like to do my doors now too.
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
#277 |
It's a suede upholstery fabric; not foam backed. I used a 3/8" closed cell foam for the shapes. It's normally used for landau tops and is considerably more rigid than regular, open cell foam.
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192 Instagram: lofab77 |
#278 |
Looks good. What dye are you using?
87 Crewcab Dually 66 Cadillac Sedan deVille 55 Chevy Belair 33 Plymouth sedan 03 S-10 86 S-10 Blazer _____________________________________________ IG drivewaycustoms |
#279 |
It's made by SEM. For what it's worth, they all appear to be the same stuff. I've used the duplicolor as well on other projects and it works just as well. The trick to get it to soak/hold better is to not just clean the surface, but wipe it all down with a multi purpose solvent prior to application.
#280 |
Tackled the dash today. I'd considered swapping to another dash, but the doorpanels turned out so well, I figured I'd take a stab at this too.
![]() ![]() ![]() Neighbors kid kept sneaking food out of his kitchen and bringing it over to me...his mom wasn't pleased...lol. He's my biggest fan. ![]() This literally took me all day...finally got it all back together right as it got dark. ![]()
#281 |
looks awesome. Nice work.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#282 |
Very cool. I have a thing for flames. Most I see, I really don't like, but yours look good.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#283 | |
I spent some time attempting to wrap some of the interior cladding in suede. It didn't go well. I finally just dyed it to match the rest. Then I fabbed up some brackets to mount the buckets. I got the two front ones in. I hope to have the two rears in tomorrow. ![]() ![]() ![]()
#284 |
Headed out to its first show today. Had a very positive response and walked away with 1st place.
#285 |
Nice, congratulations.
#286 |
That is super!
#287 |
Thanks Daddyjeep & 75Dually. It came as a surprise since it's still "under construction". But I'll take it! :-)
#288 |
I need a little help. Ive searched all over and can't seem to find a definitive answer to what size headlights I have. They're out of an 89' burb and I know that the crew cabs of the same year also had the quad lights. One of my high beams was cracked when dude backed into it so I figured now is a good time to upgrade. LMC lists these as a "150mm" headlight. I didn't have a very positive experience with them when I bought my new headlight doors and thier replacement lights are quite expensive. Every website out there seems to be confused as to which headlights came on this year. Some say 7x6, others list a composite...nothing is correct. Are these just 4x6? I'm assuming that a lot of the 80's cars used the same ones.
#289 |
I'm just glad to be here!
Here are the part numbers for the stock replacements:
ACDELCO H4701 High Beam ACDELCO H4703 Low Beam They are 150mm Wide and 92mm Tall.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#290 |
Thanks Aggie. I was hoping to find some LEDs but it seems that these are a strange size and there's not much available.
#291 |
Spent some time working up a bracket and getting everything lined up to run a York 210.
#292 |
thats pretty slick looking
#293 |
I was able to get everything hooked up yesterday. The distribution block that came with the compressor leaked everywhere. I spent a lot of time redoing every connection. I use pfte paste on all of my connections, but the pump gets too hot and it melted it all out so I wound up having to resort to old fashioned Teflon tape. Once I had all of the wiring and leaks sealed up I ran it up to 180lbs. At 150lbs, it started puking oil out of the dipstick...bad. I tried calling the company that modified it, but they were closed, so eventually I just capped the dipstick tube and that seems to have fixed it.
It is a lot faster than the electric pumps. I can fill 10gal from 0 to 180 in about 90 seconds at idle...a lot faster if I hammer the throttle. I was planning to get a 200psi switch, but as quick as it fills, I think I'll actually be okay with the 170. It recovers from airing up in about 20 seconds. If I can get my overnight bleed out taken care of, I'll be in really good shape. ![]()
#294 |
Bracket looks really nice. That's quick fill too. I have heard about all the oil issues with them (checking, changing, filling, etc) is it worth it?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#295 | |
I spoke with the guy that builds/rebuilds these yorks today at length. He's a mobile mechanic and has been running one since 1999 for at least 5hrs daily for his air tools. He said that they're made to pump up to 2500psi and the external lines are the weak point (meaning everything that we would attach to it). It can be made to pump way faster with some creative pulley setup. I know 75dually changed his around somehow with a different pulley from Kilbys. Mine being a brand new rebuild, the rings still need to seat I guess so the "blow by" or oil in the lines should lessen over time with use. 75dually went through his himself, so he can probably answer specific questions better than I can. For your build, I expect that you won't wait long before moving over to one of these too. This company is out of San Jose, so you could get it quickly.
#296 |
If it was me I would consider taking the drain and fill tubes off the side and simply plugging the holes. These York's don't need to be filled as often as you would think once the rings break in. They only need about 3/8" of oil in the bottom to make them run happy. Any more than that it will just end up in the filters down stream. Since I have been running mine I have only added oil back in once, and it was very little at that.
The install is super clean by the way! And to answer Tinydb84 - Yeah it's worth it! Those electric pumps are junk, and they just kill your electrical system. These are so simple, and the oil issues are way over blown. You just have to plan ahead and make smart choices with coalescing filters and water traps. I bet if you ask anyone who has had a good functioning York if they would ever go back to electric pumps, the only thing you would get is a bunch of funny stares, "like are you crazy!" BTW - I run my system at 200 psi and it takes it just a little over 90 seconds to fill 8 gallons when completely empty. Try that with an electric system... Last edited by 75Dually; 05-31-2016 at 11:19 PM. |
#297 | |
I follow both of your threads so I'm usually checking in when updates are posted. This statement has me curious:
I can see the York if you have a huge demand for air but for simple stuff I don't get why the electric pumps get such a bad rep.
#298 | |
Still, waiting 3-4 minutes (10 minutes in my case) to be able to air up and drive really sucked. I went to leave a show a couple weeks ago and a small crowd had gathered to see it lift and I had to sit there for what seemed like a year. I run pretty low everywhere so I'm always having to air up for railroad tracks, driveways, sharp turns, squirrels, etc. 10-20 second recovery is awesome! One other advantage that hasn't been mentioned is the York is nearly silent compared to the electric compressors.
#299 | |
I've heard the EDC's are 'almost silent' but my comps aren't any louder than my exhaust. They're right between the exhaust tips & you really (really) have to listen to know if they're even cycling. I just use an off the shelf alt (104amp?) for a GM serp app from Oreillys. No issues. I guess both will work just fine (I know mine does; yours as well). Nice fab work on that bracket too.
#300 |
Layin down the sound deadener. I'm doing the carpet today. Man, this is a ton of work.
