Keepin an eye out
Putting a Grant wheel on a OEM truck tilt column
I called Grant and it seems they do not make an install kit for 70-72 truck tilts/
![]() Anyone come up with a work around?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Re: Putting a Grant wheel on a OEM truck tilt column
OH, OH...I am going to run into this same issue. I hope someone has a solution.
You might try Ididit, I know they have one for their column but don't know if it will work on a factory column
69 Chevy 4x4 383 Power ![]() |
Is the tilt and none tilt column and different where it would meet the adapter? I would think it's not but never having a tilt column I wouldn't know.
1972 C10 - It might be old, but it's not slow |
I wouldn't have thought there was a difference? GM uses the same wheel for tilt/no tilt columns on the trucks.
![]() ![]() Join Date: Jan 2015
I had a grant wheel on a 72 suburban with factory tilt column I took it of another truck without tilt and fit fine didn't change a thing
![]() Join Date: Mar 2005
I had a grant wheel on my stock 70 non-tilt column, just installed an aftermarket tilt and put the same grant wheel on it. No problems.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
the difference is in the turn signal switch, cancelling cam/horn contact ring. I used a Grant adapter (part number 3163) but had to "clock" the adapter clockwise in order to get the horn contact to line up correctly with the pass-thru hole on the adapter.
