#26 |
upgrading to an older model
Re: Ideas for Kill switch/anti-theft?
I've heard of people putting 4-5 deadbolts on thier house door, locking some and not others so anyone trying to pick the locks would actually be locking some of them. if you could wire up 3-4 3 way switches so they have to be in a certain position before they would power up the ignition it would almost be like a combination lock...just thinking outloud.
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
#27 |
![]() Join Date: Feb 2001
Here are some ideas ...
Ideas for Kill switch/anti-theft? ... http://67-72chevytrucks.com/vboard/s...d.php?t=474293 cigar lighter' kill switch? http://67-72chevytrucks.com/vboard/s...d.php?t=274669 Need A Kill Switch Wiring Schematic http://67-72chevytrucks.com/vboard/s...d.php?t=105722 Easy no-hack hidden kill switch http://67-72chevytrucks.com/vboard/s...d.php?t=330972
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#28 |
Luckily in Montana's smaller towns (all towns except Helena, Butte, Bozeman, Missoula, and Billings) we usually don't have to worry about theft. When I do, I roll up my windows and take my keys out of the ignition.
"If finding your misplaced car keys involves looking in the ignition...........You might live in Montana." "If you've installed security lights on your house and garage and leave both unlocked.....You might live in Montana." "If there are 7 empty cars running in the parking lot at Wal-Mart at any given time.......You might live in Montana." |
#29 |
Many good, and funny ideas and stories in this thread. I second the "worn shifter". Mine is worn, and a little pressure in a certain place allows it to be shifted into drive. Sometimes when I go to emissions the test person will insist I place the transmission into park. I try to warn them, but they insist.
Once they realize they can't simply pull and shift, they ask me to explain, when they don't understand my instructions, they get out and let me shift it back into neutral. Anyone even look into having the Low Jack installed in their truck? I've considered it, but I don't know if they insist on installing the device themselves or if they'd sell the unit as a DIY kit. |
#30 |
My truck has an old style alarm on it. There's a keyed switch in the fender. When a door or the hood is opened, an air raid siren goes off. In the near future I am going to attach a relay to disable the starter wire when the system is active. I'd like to put a timer on the siren so it goes off for a minute after its set off, instead of stopping when the door/hood is closed.
#31 |
detachable steering wheel?? figure someone will want to steal a truck they can steer...
#32 |
![]() Join Date: Dec 2011
Four levels of security.
1.) Your regular alarm that will trip when a door opens or truck is bumped. 2.) Kill switch from HEI to somewhere hidden in the Truck. 3.) Add a Battery disconnect switch and include a by pass 15 amp fuse to ensure you maintain settings on radio etc. 3.) Final one........that always works......weld a u bolt under the hood and wrap a chain from your hood to your grill frame and put a lock on it....you make it tight enough to where you can just barely open your hood enough to see the lock and be able to open it with the key. This will eliminate from someone getting into the engine compartment and making the final adjustments to start your truck and stealing it. If you do this then you can eliminate 1 & 2 above and just have the battery disconnect, truck will not go anywhere with the exception of being towed, and if that is the case then the alarm should be put back in the equation. I had a buddy that did this to his Impala and it was genius. No one could get into his engine....not even get a peak at it. Last edited by yoncey; 06-26-2012 at 03:30 PM. Reason: addition |
#33 | |
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#34 |
Cop was telling me just yesterday that Lojack will not even start funtioning until the VIN hits some central monitoring location. This is after it is reported etc
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#35 |
When I get to the hotel tonight I post some "kill switch " links for you all.
#36 |
I remove all four wheels and set my Blazer on cinder blocks every night. I then pour a quart of motor oil and tranny fluid on the driveway under it to deter would be thieves
#37 |
My simple anti theft is I pull the in line fuse from the wire that goes to the hei, if you dont know about it it will drive you nuts first to find it then have one to replace it it is a blade fuse all the rest under my dash are old style. I know it has blown and drive me crazy till I figured out what it was.
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
#38 | |
My truck is still up on blocks but when I get her running again I plan to take the shifter lever with me. I could back up against a pole, put it in reverse, and take the 3 speed on the column lever with me. |
#39 |
Hi all. I'm new to the forum. I'm on my first restoration and my first Chevy.
My question is: I changed out the steering column and my new one does not have the neutral safety switch. As of now, I'm using a jumper so the truck can start. Is it possible to hook up a switch to this simple set up to act as a kill switch? I mean I know it can, it makes sense. I guess my question is, does the switch need to be able to handle certain volts/amps/load etc? Thanks and I'm sure I'll have plenty of questions for the group. I've been lurking and learning from you guys for a year now. |
