Old 04-07-2016, 08:29 AM   #1
pigpin
Project Pigpen 1951 5 window 3100
So here is an introduction to my current project. 1951 Chevy 3100 5 window. The truck is from Kansas and the plate on it expired in 1982. Pretty solid and complete truck. typical broken glass, rusty floors and cab corners but pretty much all there. Plan is Mustang II front, 4 link rear, LS motor, and air ride. I don't plan on painting it. And the due date is early June, I really started on it August of last year so that's not as bad as it sounds.
pigpin is offline   Reply With Quote
Old 04-08-2016, 08:39 AM   #2
pigpin
Re: Project Pigpen 1951 5 window 3100
Disassembly went quick. I didn't break a single bolt taking it apart.
Old 04-08-2016, 08:58 AM   #3
Katrina/10
Katrina/10's Avatar
Nice progress so far.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 04-09-2016, 12:49 AM   #4
joedoh
joedoh's Avatar
nice progress, is that crew cab long bed SRW a factory truck? gotta be a unicorn (one of one)
I see the SG on the tag, did it come from around wichita?
Old 04-09-2016, 09:28 AM   #5
pigpin
Yup, 2000 C3500 crew cab long bed SRW. I've had it 15 years been a great truck but currently chasing one of those evil C/K truck electrical gremlins.
Yes the truck is from somewhere east of Wichita.
Old 04-10-2016, 08:58 AM   #6
Sim6
Sim6's Avatar
Looking good pigpen.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 04-11-2016, 12:41 PM   #7
pigpin
1999 4.8LS off of Craigslist, fingers crossed.
The start of rust repair.
The fleet:
2014 Ram 1500 Express, ya its a Hemi
2009 Jeep Liberty Sport- the wife's ride
2000 Chevy C3500- the work horse
1972 Plymouth Custom Suburban Wagon 5.7 Hemi swap
1951 Chevy 3100- project pigpen
Old 04-11-2016, 12:42 PM   #8
pigpin
And a cab corner.
The fleet:
Old 04-12-2016, 03:37 PM   #9
69CST-V
69CST-V's Avatar
Looks good....following
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 04-12-2016, 06:56 PM   #10
pigpin
Mustang II front crossmember, boxing plates, tubular arms, 2" drop spindles, 5 x 4.5 bolt pattern rotors, 2500# Firestone bags. Ford 8.8 rear end out of an Explorer, generic four link kit, C-notch, 2600# Firestone bags. It's just tacked together in this pic to make sure everything fits right.
Other cab corner.
The fleet:
Old 04-12-2016, 11:32 PM   #11
DeanTX
DeanTX's Avatar
Nice start to the chassis. Can't beat the Ford 8.8 out of an Explorer. Very strong rear end.
DeanTX is offline   Reply With Quote
Old 04-25-2016, 08:00 AM   #12
pigpin
I tore the rear end down for new seals and gaskets.
Made motor mounts and checked motor and cab clearance. I ended up modifying the headers to clear the frame.
I'm using a steering column from a square body S10, pedal assembly from a 1999 Jeep Grand Cherokee. The start on modifications to the firewall for all that.
1955 Bel Air wheel, S10 bench seat.
This is as far as I went with mockup before taking all back apart to sandblast and paint the frame.
The fleet:
Old 04-25-2016, 08:02 AM   #13
pigpin
One more with hood just set on.
The fleet:
Old 04-25-2016, 08:08 AM   #14
pigpin
Satisfied everything was going to fit, I took back apart to finish weld everything.
Sandblasted, Por15, and top coated the frame.
and reassembly started.
The fleet:
Old 04-27-2016, 07:48 AM   #15
pigpin
I sectioned my deep truck oil pan about 1.25" and tig welded it back together. It doesn't leak but it was a real pain.
Engine and trans in the frame for the final time.
My DIY harness.
The fleet:
Old 04-27-2016, 10:10 AM   #16
oldman3
oldman3's Avatar
Like how you are doing this, will tag along for the build...Jim
oldman3 is offline   Reply With Quote
Old 04-27-2016, 10:45 AM   #17
RockinKees
RockinKees's Avatar
Just read this.
You take it seriously
Very nice work so far!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 04-27-2016, 10:50 AM   #18
fisherman420
I like where your headed with this, nice work!
fisherman420 is offline   Reply With Quote
Old 05-10-2016, 08:19 AM   #19
pigpin
Work done on the cab.
The fleet:
Old 05-10-2016, 08:39 AM   #20
pigpin
And the first start before I put the cab on.
https://youtu.be/unPKwqiN0cs
The fleet:
Old 05-12-2016, 03:05 AM   #21
cotsi95
Looks great. What radiator are you using?
cotsi95 is offline   Reply With Quote
Old 05-12-2016, 07:25 AM   #22
pigpin
I'm using Speedway Motors Part # 9175159 for the radiator. I had to modify the top of the radiator support to get the radiator as far forward as I wanted it. I didn't want to use an electric fan or a shallow oil pan so I ended up mounting the motor higher and farther back in the chassis than most. the down side of that was that I had to add clearance in the fire wall for the back of the valve covers and my transmission tunnel is bigger.
The fleet:
Old 06-02-2016, 04:59 PM   #23
pigpin
Primed and painted inner fenders and core support.
started wiring using my DIY engine harness and a Speedway Motors kit
gauges are from dolphin
The fleet:
Old 06-02-2016, 05:02 PM   #24
pigpin
A quick look at the rear suspension setup.
The fleet:
Old 06-03-2016, 01:29 PM   #25
Cuttin up
Cuttin up's Avatar
Lookin good
my 54 s10 build
Cuttin up is offline   Reply With Quote
