Old 06-02-2016, 10:37 AM   #1
35boulder
35boulder's Avatar
Seat Belt Install
I'm getting ready to install my new seatlbelts from Morris. Am I correct in assuming that I will need to remove the bench seat to do this? Thanks
35boulder is offline   Reply With Quote
Old 06-02-2016, 10:46 AM   #2
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Seat Belt Install
I've only removed the re tractor belts, and that was with the seat in...3/16" head bolt and washer. I have the "luxury" of pulling everything, so the bench is coming out anyway. But, looks to me that no, you do not have to pull the seat. That is, unless your arms are shorter than 1.5'.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-02-2016, 11:51 PM   #3
joeydurango
joeydurango's Avatar
I just installed my Morris belts without pulling the bench. It is definitely possible. But I won't say it was easy... a bit of contortionist posturing is necessary, and it helps to have a ratchet with very fine engagement for the bolts under the seat. A U-joint socket adapter helps too. Finally, make sure you PB Blaster the heck out of the seat belt bolts under the floor of the cab before you begin - sure makes it a lot easier to thread them out without fighting them every bit of the way.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 06-03-2016, 11:13 AM   #4
35boulder
35boulder's Avatar
Thanks to you both for your answers and hints.
Old 06-03-2016, 01:16 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
I don't know about Morris belts, but I put my GM belts in my 70 with the seat in, slid all the way forward, and the gas tank in. Like mentioned, a fine tooth ratchet will be your friend. It was not bad, as I lubed the holes and cleaned the bolt threads with a wire wheel, and then lubed the bolt threads too. Good luck, post some pics before and after the install.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-03-2016, 01:43 PM   #6
joeydurango
Haha! Didn't even think to try sliding the seat forward. That might have helped.
Old 06-03-2016, 07:19 PM   #7
71CHEVYSHORTBED402
I was introduced to an adjustable bench just last week. It hasn't worked since I bought it (1989)..........Very cool, only I'll be pulling the bench soon.
I couldn't seem to start my LH retract without a 13/16" wrench, which happened to be the only one I didn't have. $3 for an old thorsen combination at the local pawn shop.
Tony
