Old 06-03-2016, 07:29 AM   #1
Ed F
Ed F's Avatar
High pitched hum
My '70 is developing an intermittent high pitch hum. It's not a squeal. It is drive line related not rpm related. Doesn't matter what gear it's in (3 speed manual) or if the clutch is in or out. Doesn't do it under acceleration. More often hear it when slowing down. Front wheel bearings are good. Iam wondering about drive shaft bearings or u joint. Any input would be appreciated.
Ed F is offline   Reply With Quote
Old 06-03-2016, 08:01 AM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: High pitched hum
Any vibration with the hum?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-03-2016, 08:37 AM   #3
n33k0
Check the fluid in the differential. I had a leaky cover and when the fluid got low it would make noise, most notably when at low speed or decelerating.
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 06-03-2016, 04:46 PM   #4
Ed F
Ed F's Avatar
No vibration. I know the differential was full a year ago and I haven't seen any leaks, but will check that and the transmission.
Old 06-03-2016, 09:56 PM   #5
70STOVEBOLT
Typically if the noise is only under deceleration, it signals a problem with the differential.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 06-03-2016, 10:36 PM   #6
jocko
jocko's Avatar
Could be Neil Young.
Old 06-04-2016, 03:12 AM   #7
El Dorado Jim
Originally Posted by 70stovebolt View Post
typically if the noise is only under deceleration, it signals a problem with the differential.
x2
El Dorado Jim is offline   Reply With Quote
Old 06-04-2016, 01:35 PM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
For the cost involved I'd replace the 3 u-joints and steady/carrier bearing. If the noise still persists then I go into the diff.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-04-2016, 10:24 PM   #9
swamp rat
swamp rat's Avatar
I agree with 70Stovebolt
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
