Old 06-03-2016, 10:48 PM   #1
ck5566
Small block Fuel pumps??
Is the only difference's in fuel pumps being the bottom inlet & outlet lines Orientation setups in which way they are pointing & is the threaded outlet all the same size. I am having a tuff time in finding a line setup that will work with my 1989 305 ci eng. from a Pont. Firebird. Most to all Catalogs only go up to 87/88 for trucks not cars. I know I am going to have to do some modification to the line closest to the carb ( its a Holley) thats a given there. any help or direction would be great, thanks.
My truck is a 68 C10 lwb coils all around
ck5566 is offline   Reply With Quote
Old 06-04-2016, 10:04 AM   #2
Redline novdog
Redline novdog's Avatar
Re: Small block Fuel pumps??
Not quite sure what you're wanting, but the fuel pump specific to your '68 with a SBC should work, unless you have altered the tank and lines. Newer pumps had 3 ports ( for emissions). As long as the cam in your '89 305 has a fuel pump lobe, factory pump for a '68 small block should work fine.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 06-04-2016, 10:16 AM   #3
ga-stepside
ga-stepside's Avatar
I'm also not sure what you need but I just got this pump from Summit. The bottom is clockable so you can orient the in/out ports.
http://www.summitracing.com/parts/sum-250020-1b
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 06-04-2016, 11:57 AM   #4
ck5566
I can see were the clocking would come in handy but dont need to pay 2 X's what a stock pump cost, thanks anyway
Old 06-04-2016, 12:31 PM   #5
ck5566
I am looking for a hard line coming from the fuel pump to the carb (Holley), at the end of hard line at carb I pretty much know it might need to be modified and the threaded end at fuel pump are the thread sizes all same 1/2 X 20 I think. I just want to get rid of the rubber line from pump to carb and get rid of the (emission outlet) for a much cleaner look. A 305 is still a small block with a fuel pump push rod just like all other SBC eng's so I guess since I have a machanical pump it does have a cam lobe that pushes the fuel pump rod. So is a SBC fuel pump a fuel pump is a fuel pump only with the exception of the (emission port). Am I making sense here?
Old 06-04-2016, 02:24 PM   #6
Redline novdog
Ok I think I get it. On my '67 the fuel line is 5/16" . on '80s sbc the fuel line was 3/8" . Are the fittings the same size for both????? I do not know,but if you can get that info , you should be able to buy the correct fuel line/or make one!!!
Old 06-04-2016, 04:34 PM   #7
ck5566
So I guess if I buy a fuel pump for a let say a 68 w/307 or 327 eng's and then I should be able to get a stock hard line for the 68 setup? I know at the carb the hard line will need to be modified for my Holley carb.
Old 06-04-2016, 07:32 PM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I bent my own 3/8" steel fuel lines from my mechanical pump to Holley carb.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-05-2016, 02:31 AM   #9
Redline novdog
Yes
Old 06-05-2016, 05:15 AM   #10
ck5566
Yes
Good then I need to go on the hunt for some new parts. LOL .
