Closed Thread
Old 06-02-2016, 07:27 PM   #2351
Hugh in NC
Hugh in NC's Avatar
Re: What did you do to your truck today part III
Don't forget your seals around the top front and the sides of the radiator and the support. Unless if there are any gaps it will let the air bypass the radiator and not cool as efficently.
I made my side seals and front top seal, but you can see about what the 3rd pciture has for a factory (if all the pieces were still on it) looks like. It makes a tremdous difference on cooling ability, especially on the highway or if you have AC.
Thanks for the information. There were no seals on the old radiator and I did not know any better. I will get that fixed.
Thanks,
Hugh
Hugh in NC is offline
Old 06-02-2016, 07:58 PM   #2352
OldChevy61
OldChevy61's Avatar
Not all today,just catching up.lol. Inner fenders and core support bolted on. Windshield and back glass installed and grill support blasted and epoxied this evening.
OldChevy61 is offline
Old 06-02-2016, 08:00 PM   #2353
robber grin
Changed the transmission out due to lack of reverse
had a drive shaft made and installed it.
Replaced the headlight switch and some bulbs and sockets
Changed the Proportioning Valve down on the frame.
That's enough
robber grin is offline
Old 06-05-2016, 05:59 PM   #2354
mjh1965
mjh1965's Avatar
Well I got a little more done today on the cab . With if going to the blasters next weekend , I decided it would make more sense , to weld up the hole in the transmission tunnel .
I think the previous owner should have purchased a grinder with a cutting wheel . If you think the dash was bad take a look at the hole he cut in the tunnel . I think they used a coal chisel and the a pair of grips to bend the cut metal over .
The way the dash had been cut
The transmitting hole
The under side
So first I cleaned up the part I cut from my old cab floor
I then welded in the new part
After welding it in I cleaned it up
Then I welded up the hole that was for the second tank
I also welded up the holes left after I removed the jack brackets on the floor .
So with the floor all cleaned up it's ready for blasting next week .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 06-05-2016, 06:46 PM   #2355
65chevysub
65chevysub's Avatar
I finally got some gray primer on the old girl today. My daughter is bummed as she cant call it an Oreo anymore
65chevysub is offline
Old 06-08-2016, 11:07 AM   #2356
jteck10
jteck10's Avatar
Had a bit of a busy few days with Loretta, installed a new passenger side fender, new hood, and new bed-wood i sanded stained and sealed. now to dive into the engine a bit more
1962 GMC 2500 3/4 ton longbed stepside (currently w/flatbed), 4 on the floor, 305-V6-5.0L
jteck10 is offline
Old 06-08-2016, 12:24 PM   #2357
DLW
The under side
Nice job fixing all that! Might of been a good time to change to a high hump ..
DLW is offline
Old 06-08-2016, 12:42 PM   #2358
Northwest Outlaw
Northwest Outlaw's Avatar
After letting the painted engine sit for two weeks, let's say it was to "let the paint cure" and not cause i'm lazy... I finally got around to moving along with the spruce up. Headers were sanded down and repainted, valve covers painted (thinking of adding red to the top of the fins or maybe in between?) painted and installed the Edlebrock Performer intake and the distributor got new cap, rotor, points and condenser. A step closer to the first test fit in the truck.
Also found that my new brakes leak when I bled them, yay. I've contacted McGaughy's warranty department and they should be sending new parts this week.
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline
Old 06-13-2016, 09:13 PM   #2359
OldChevy61
OldChevy61's Avatar
She's got fenders once again.
Old 06-13-2016, 09:38 PM   #2360
Backpayne
I was attempting to remove my rear coil springs to install lowering springs, but I broke both bolts going through the trailing arms. I was able to use an air chisel to push the driver's side bolt through but cannot budge the right side bolt. I drenched it with penetrating oil and will let it sit overnight.
The upper bolts are soaking, too.
Backpayne is offline
Old 06-14-2016, 07:19 AM   #2361
robber grin
Picked it up at Dwayne's House of Hot~rods and DROVE it home...
took my wife and son on their first run in it... # honey take me for a spin
made some adjustments and DROVE it to N@P@, where the fellows have been waiting for several years to see all their parts back in one place.
Then DROVE to the Sonic Car Cruise...
visited with some Road Mutt CC alumni and DROVE it to my buddy Keith's (he's building a 63 GMC shortwide)...
then you guessed it, DROVE it to my buddy's down on Mopar Alley and visited some more...
Then just for fun, DROVE it home...
four years since it all began and other than dragging two or three times (PA) it was a great evening of DRIVING.
Old 06-14-2016, 01:21 PM   #2362
earl84
Haha, I get the reference. Glad to hear you're driving it again.
earl84 is offline
Old 06-14-2016, 06:18 PM   #2363
I think everyone of mine that I did (the first time) snapped off too. I had one that took a soaking or too before it would punch thru.
Palf70Step is offline
Old 06-14-2016, 06:35 PM   #2364
jayoldschool
Moderator
Installed a Precision windshield gasket, bled the brakes after installing the new dual master cylinder, and... drove it! Good to be back in the saddle again. It's running great.
jayoldschool is offline
Old 06-14-2016, 07:11 PM   #2365
ironman3452
ironman3452's Avatar
I know, but I am going to say it any ways, you guys have it easy, finding the repair parts, for your trucks, but us guys who have panels, it is a different story, sure from the back of the front doors, it all looks the same, but from the back of the doors, it is a whole different story, I have looked for repair parts, and it seems like no one makes them, so what is a guy going to do to fix rusted panels, I need a repair panel for the passenger side rear, just above the light housing, to the lower end, and does any one know if a long wheel base side, will work to replace the one above the wheel, if any one knows, please let me know http://67-72chevytrucks.com/vboard/a...817=1465945817
ironman3452 is offline
Old 06-14-2016, 09:14 PM   #2366
Backpayne
Had to cut the spring then the bolt sticking up but I was finally able to air chisel that darn thing out. The bolt was bone dry even filling the spring retainer with PB Blaster. Not a drop found its way in.
Old 06-14-2016, 09:29 PM   #2367
TJ's Chevy
TJ's Chevy's Avatar
I ordered a new set of tires for my GMC today.
TJ's Chevy is offline
Old 06-15-2016, 09:38 PM   #2368
TJ's Chevy
TJ's Chevy's Avatar
New tires came in for my GMC today! And here's a picture of the new set of rims.
Old 06-15-2016, 11:16 PM   #2369
Slow Build
Slow Build's Avatar
Strange....They look like OFF-ROADIAN tires to me.
Sorry couldn't control myself.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 06-16-2016, 12:57 AM   #2370
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by slow build View Post
strange....they look like off-roadian tires to me.
lol!
Old 06-16-2016, 08:11 AM   #2371
robber grin
Soooo... an update on the wretched electrical gremlins (etc.) in my 62 C10.
I had a constant generator light on the dash with the key off.
Called my buddy Sam (street rod builder extraordinaire) in Mt. Pleasant, who said "Can you get it out to me this afternoon?" Soooo I did.
On the way the hardware holding the down pipes to the ram-horns rattled loose and I nearly dropped my exhaust on 119 South.... and it certainly got LOUDER than it normally is, but do you think yours truly caught the change in tonal... you guessed it. Nope mesmerized by the sheer fact I'm driving.
To add insult to injury, my D.S. peep vibrated loose and now resides somewhere between here and there.
Discovered the 1/4" line coming off the master was dripping DOT 3 pretty good on my freshly painted inner fender so we tightened it up... and went on with our electrical work.
With some patience, superior intellect, and a single 12V test light he worked every pending electrical issue out of the truck.
During the alternator conversion to the generator/forward lamp harness, we mis-wired one small red lead to the junction block that apparently is not used after you abandon the external voltage regulator. So we pulled it off the junction block, taped it up, and abandoned it in the bundle.
No light and system is charging!!!
Sam sees things we mere mortals (I) can't. He even threw in a pair of peeps to replace the one that went AWOL. Before I rolled out he tightened and replaced the missing hardware on both manifolds too. Sam's a ruler.
SO the drive home was so much quieter and even had the option of using turn signals, which really is not commonly done around here anyway, but never hurts.
Happy, happy... everybody happy - right?
Well almost.
Seems the 1/4" brake line that was leaking at Sam's, popped through the flare nut and re-baptized my truck in DOT 3 (paint remover).
The hidden blessing is no one was hurt and the truck can be fixed.
I will have to shoot the D.S. front fender again, but that's life when you can't properly hand flare mild steel tubing... which obviously I cannot.
Peeps are on. Tubing is up at Dwayne's House of Hot Rods for a hydraulic double flare job and tonight we BLEED again!
Old 06-16-2016, 09:26 AM   #2372
The Rocknrod
Moderator
The Rocknrod's Avatar
Peeps
The Rocknrod is offline
Old 06-16-2016, 09:47 AM   #2373
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
peeps
pēps/
nouninformal
plural noun: peeps
people (often used to refer to a person's friends or associates).
"thanks for the feedback, peeps!"
aerotruk63 is offline
Old 06-16-2016, 10:15 AM   #2374
robber grin
peeps
pēps/
nouninformal
plural noun: peeps
Or in this case an aftermarket side view mirror commonly employed on hot rods, street rods, and all manner of specially constructed vehicles.
Similar to the one pictured here on my 62 where it was formally mounted.
Old 06-16-2016, 10:22 AM   #2375
60chevyjim
60chevyjim's Avatar
Originally Posted by The Rocknrod View Post
Peeps
small round outside rear view mirror's that clamp onto the edge of the door.
60chevyjim is offline
Closed Thread
