Old 06-06-2016, 10:19 AM   #1
aod92
aod92's Avatar
Idle temperature?
What temps are you guys getting too after idling for a few minutes? My truck stays around 180 while driving and about 220 when idling. It seems like my electric fan isn't keeping up. Is that too warm or is that a normal temp when not moving?
aod92 is offline   Reply With Quote
Old 06-06-2016, 11:21 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Idle temperature?
Mine runs 175-185 all the time..what size cfm fan are you running? I've got dual fans on mine and when idling both run..fan 1 comes on at 175 and fan 2 comes on at 185..what truck is the engine in? Have you had it running long? Did you get all the air out of the engine?
Old 06-06-2016, 01:07 PM   #3
aod92
aod92's Avatar
I've had it running about 2 months now. All the air is out. It's a 6.0 lq4. The dual fans are EBay fans and are supposed to be 1400 cfm each. Not sure if they really are. I need to tune my fans to come on sooner too. They don't turn on until about 210.
Old 06-06-2016, 02:32 PM   #4
mongocanfly
If they don't come on til 210 that may be it..what thermostat do you have?
Old 06-06-2016, 03:48 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
In traffic with a stock stat I idle around184-190. On a 102* on an asphalt lot I saw 214 while still, but cooled immediately under movement.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-06-2016, 04:11 PM   #6
aod92
aod92's Avatar
160 t-stat
Old 06-06-2016, 04:13 PM   #7
aod92
aod92's Avatar
Mine seems to cool pretty quick while driving too. That's what makes me think the fan is either not powerful enough or it's coming on too late and it's harder to cool down.
Old 06-06-2016, 06:39 PM   #8
mongocanfly
Mines got a 160 tsat to..I think my fans are like 2600 cfm each..they told me to get the biggest fans i could fit and thats what i did..on the other side my 2013 gmc everday truck runs 210 all the time..
Old 06-06-2016, 07:13 PM   #9
truckdude239
truckdude239's Avatar
195-205
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-28-2016, 06:10 PM   #10
lowrodderchev
lowrodderchev's Avatar
where do you guys check to see what temp it is? I'm running 2 fans its 102 today and I notice my gauge started to mark the half point. I've only been driving the truck a few days but its usually at the 1/4 point. I also seen something about air in the system. how does one bleed the air out? thank you
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-28-2016, 06:34 PM   #11
aod92
aod92's Avatar
Some scanners will show you the temp the pcm is reading
Old 06-28-2016, 06:48 PM   #12
lowrodderchev
those scanners aint cheap LOL I still haven't bought a code reader few people told me I should get one if I'm doing this swap
Old 06-28-2016, 07:28 PM   #13
mongocanfly
Lowrodder..I assume you have a gauge that don't have numbers...i don't like em..hard to tell what ya got numerically..you need to get a temp number first then go from there..getting the air out of a ls engine is done simply by taking the top hose loose from radiator and filling the engine completely with coolant..that's how I did mine anyway..
Old 06-28-2016, 07:45 PM   #14
lowrodderchev
yes sir no numbers just Cold and hot (75 chevy blazer) I filled mine up from heater hose to so I'm guessing I'm good. going to purchase a infrared thermo today and see were I'm at just wasn't sure if there's a certain spot to get a reading from.
