Closed Thread
Old 06-04-2016, 04:46 PM   #3826
In The Ten Ring
Re: What did you do to your truck today? Chapter II
At the moment I am letting the second coat of Mar Hyde dry on my air cleaner cover.
Here is the part after derusting.
In The Ten Ring is offline
Old 06-04-2016, 07:15 PM   #3827
OregonNed
OregonNed's Avatar
Was wet sanding some, but man it is 95 here, so I am off until evening.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 06-04-2016, 11:05 PM   #3828
Rich69shortfleet
I installed my new gauge cluster housing now sporting a full compliment of factory style gauges. I only had to pull it back out once, the damn printed circuit had a bad spot and one strip short circuited and melted. I was able to fix it with a bypass but I shouldn't have to with a brand new part. Anyway, finally got everything working. Then I started in on my Digi-Tails LED tails install. Egad they make it complicated, more complicated than it needs to be I think. And then they have an error in their instructions about the size of mounting holes to drill. This caused a good hour's extra work to compensate once the holes were drilled. For the price they charge, their instructions should at least be accurate.
Rich69shortfleet is offline
Old 06-05-2016, 12:31 AM   #3829
VWNate1
VWNate1's Avatar
Thumbs up Original Air Cleaner
I can't wait to see it finished , will you be adding the OEM AC Filter decals ? .
Is it a dry or oil bath typ ? .
-Nate
VWNate1 is offline
Old 06-06-2016, 03:02 PM   #3830
Rich69shortfleet
Yesterday I pretty much completed the install of LED lights all around. I started a separate thread with a link to a Youtube video if anyone is interested.
Old 06-08-2016, 03:07 PM   #3831
Metaldoc
Metaldoc's Avatar
Originally Posted by VWNate1 View Post
Horns are pretty easy to re awaken ~ you need a good battery and test light , test for continuity , if there's continuity *slowly* tighten the adjuster screw until the test light goes out then back it off -barely- until the light comes back on , mount it and test it ~ the adjuster is really sensitive , a 1/10th turn is a lot .
I always recommend using a relay in heavy current consumers like horns .
The older ones , you can drill out / grind off the rivets and polish the contacts , , re assemble and adjust to suit .
Remember ! : a horn will not sound correctly unless it's solidly mounted .
I just tried this process and I thank you, I don't have to go and replace mine.
Metaldoc is offline
Old 06-08-2016, 05:19 PM   #3832
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Cool ~ .
As I said , I like and prefer fixing things .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 06-08-2016, 06:41 PM   #3833
C-10 Norway
C-10 Norway's Avatar
Lace painted the roof, and painted the logo on the doors of my shop truck today.
Quite satisfied to be honest.
And I had to do something about the result of a lousy painter who did the paint and prep work for the previous owner.
Driver carries no cash. He's married.
'67 Chevrolet C10 SWB - 350 Vortec/TH700R4
Backyard Engineering
C-10 Norway is offline
Old 06-08-2016, 10:59 PM   #3834
Rich69shortfleet
I installed dome light switches and courtesy lights. Can't believe they built so many of these without door activated dome lights. It got too dark as I was working so I left it until tomorrow to tidy up the wiring and better attach it up under the dash.
Old 06-09-2016, 08:06 AM   #3835
Andy4639
Old member
Andy4639's Avatar
I got the bed cover alarm switch installed to go with the rest of it. I have a nice working system with shock senor and doors hood and bed cover triggers.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 06-09-2016, 12:26 PM   #3836
Metaldoc
Metaldoc's Avatar
drove it up and down the street for the first time.
Metaldoc is offline
Old 06-09-2016, 01:37 PM   #3837
Mator
Mator's Avatar
That's funny, I couldn't wait to drive mine just like that. No windshield hood or bed. But man it was a since of accomplishment. Good for you.
Mator is offline
Old 06-09-2016, 02:01 PM   #3838
Rich69shortfleet
Finished installing the courtesy lights. Found some pre-existing holes in the bottom of the dash so I didn't even have to drill any extra holes! Love when that happens.
Old 06-09-2016, 03:08 PM   #3839
slaughter442
With the help of a great guy Thanks Adam My new to me 72.
slaughter442 is offline
Old 06-09-2016, 09:31 PM   #3840
rsgt
rsgt's Avatar
Your 72 looks like mine. Mine is fairly new to me. You can see it on my build thread.
rsgt is offline
Old 06-09-2016, 10:02 PM   #3841
In The Ten Ring
Re: Original Air Cleaner
-Nate
Brother, I have gone round and round just deciding what shade of black to paint these! I even checked on powder coating. Yes, I would like to have decals for these, at some point.
Right when I had decided to paint them in gloss (after painting this piece in Mar Hyde satin), I looked under my hood at all my other rusted engine parts and realized.....no matter what I do, this part will look out of place. LOL
Old 06-09-2016, 10:04 PM   #3842
In The Ten Ring
Today I made a huge advance! Not to my truck, all I did to it was to rust treat some rusty screw holes.....but I helped the freight truck driver load up the two crates I built for the fellow member in Canada! I had to get those out of the garage so I could get the room to get back on my truck. Seeing that box truck leave caused me to almost jump for joy!
Old 06-10-2016, 11:05 AM   #3843
VWNate1
VWNate1's Avatar
Post Re: Original Air Cleaner
Yuo're correct ~
It's supposed to be glossy black .
Agreed it'll look out of place for a while but that's normal in regular Service and Repair .
I still don't know if it's oil bath or paper element typ....
-Nate
VWNate1 is offline
Old 06-10-2016, 11:09 AM   #3844
VWNate1
VWNate1's Avatar
I loaded some stuff in the bed and scratched the heck out of the new paint and Its still not drive able yet =8-^ .
C'est la Vie , it _IS_ my Shop Truck .
-Nate
Geezer
VWNate1 is offline
Old 06-10-2016, 09:25 PM   #3845
Metaldoc
Metaldoc's Avatar
This the first trail fit with all the boards and bars. Looks great and with it being composite it is finished once I screw it down. I need to trim a little off some edges but that's it.
Metaldoc is offline
Old 06-10-2016, 10:22 PM   #3846
In The Ten Ring
-Nate
A member on here told me mine was a dry air cleaner. When I mentioned how oily it was, he explained that was due to how badly worn out the engine it came off was.
Old 06-11-2016, 10:18 AM   #3847
snipescastle2
snipescastle2's Avatar
Talking Re: What did you do to your truck today? Chapter II
I finished installing my door glass and regulators, looks like I'm gonna be buying a new set of regulators though, seems they are very hard to operate,the passenger side more than the driver side.
First impressions of my new electric vacuum pump set up for my brakes was well worth the money I spent in setting it up.you can barely hear the pump when it's running and I never had any problems braking,whatsoever.
I still need to get an alignment, I can hear my tires squalling going into turns. But other than that, I guess I'm almost ready to graduate
Pictures to come later.
Have a great weekend!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline
Old 06-11-2016, 10:31 AM   #3848
drfloyd
Drilled and bolted my front 4 link brackets after cleaning and priming the mating surfaces that will get missed by powder coat so far. The No Limit stuff is really nice. I plan to finish up the upper coilover mounts as well today and get things aligned in the rear. Then it's on to the "cross" member placement and I can finish cutting out the old cross members and boxing the frame. Then I'll get it all welded up.
drfloyd is offline
Old 06-11-2016, 01:14 PM   #3849
RodnRudy
RodnRudy's Avatar
This was done Thursday actually. I took advantage of a calm morning and got the white sprayed on the top. I added some flattener to the paint, don't want it to look too new and shiney.
RodnRudy is offline
Old 06-11-2016, 01:25 PM   #3850
zellway
zellway's Avatar
That's a great looking truck! And I see already rolling on rally wheels! Any more changes to come?
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Closed Thread
