Old 06-07-2016, 09:09 PM   #1
CG
BlahBlahBlah
Swapping the front clip
So right now I have a 68 GMC clip on my K20. Im going to put a 72 Chevy front clip on it instead. I have all the correct sheet metal. Just need to know what I need to do to mount the new core support. Seems like the doughnuts and bolts are different ... or maybe they are different on 2 wheel to 4 wheel?
No real idea ... help a fella out
Old 06-07-2016, 09:17 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Swapping the front clip
Pretty sure all you have to do is drill the front core support mounts on the frame to accept the later model bushings on the 72 core support . East peasy !
Old 06-08-2016, 12:00 AM   #3
CG
BlahBlahBlah
Does sound easy peasy, Ill have to contact one of the local vendors to get the correct core support mounts
Old 06-08-2016, 02:11 AM   #4
midniteblues
midniteblues's Avatar
you would need the 69-72 core support mounts.
i do believe the 68 gmc bumper is differnt than a 72 chev. also the outer brackets.
front headlite harness.
well you could use the gmc harness on a chev clip but it will take some modding to make the single 72 chev headlights work correctly. not to mention side marker lites that actually lite up on a 72.
dont get me wrong i like the 71-2 grills but the gmc is so much less common.
even with the slightly missmatched colors on your truck i would leave it be till i was ready too paint.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-08-2016, 06:40 AM   #5
cleanfreak
cleanfreak's Avatar
I'm not positive , but I think the core support is the same at the mount area, as long as the mounts match the frame , 67-68 , or 69-72 , just re-use whatever core support mounts were there.
cleanfreak is offline   Reply With Quote
Old 06-08-2016, 02:43 PM   #6
CG
BlahBlahBlah
I have the correct bumper and brackets. Believe me I tried to love the quads headlights, but I just really love the Chevy more.
And looking at pics of a ton of 4x4s, and my last two, I really like the largeness of the 71/72 front on a 4x4.
And I did forget about the harness, but I have boxes of harnesses, so Ill see what I have there.
Old 06-09-2016, 11:01 AM   #7
midniteblues
It's the little things that we so often forgot about that makes a small project take forever. I know all about that.
I wasn't sure if your clip still had a light side harness in it but I figured I would mention it.
And I totally agree on the 71-2 grills they are sweet. It's just around here I really don't see gmc grills very often.
Old 06-09-2016, 12:23 PM   #8
michael bustamante
michael bustamante's Avatar
got a pic of the GMC front clip? or are you not thinking of selling it
1967custom
michael bustamante is offline   Reply With Quote
Old 06-09-2016, 01:47 PM   #9
CG
BlahBlahBlah
Im keeping everything except the grill, it will be going to Maryland when I get around to doing the swap.
The GMC fenders and hood are the same as 67-68 Chevy and the core support is easily changed to Chevy, so Ill be keeping that too.
