Visor and Visor Bracket Screws
I plan on running to the hardware store to get the screws for the visor and visor clips. This is for a 69 K-10. Does anyone know which size these should be. I plan on buying either Stainless or black, depending on what they have in stock. I know they are a Phillips head type of screw, but I need the length and size/gauge please.
![]() Join Date: Dec 2013
Re: Visor and Visor Bracket Screws
#8 3/4" Phillips oval head or #10 with an 8 head if the holes are loose. stainless don't come in oval head , try ace hardware
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Thank you for the quick reply. Do both the visors and the visor clips use the same screw then? for some reason I thought maybe they were different.
Pretty sure there the same , just buy a couple longer there cheap like .10 buy a hand full
