1990s hubcaps for C20
I have been looking for original GMC hubcaps for a long time and havnt had much luck. I noticed people have used 1990s hubcaps and really like the look. i want to try some out but have not found any details on using them anywhere. Do these need any modifications to work or will they fit with no issues? also anybody know off the top there heads which lug nuts i would need? i have a stock 1972 gmc C20 with the dana 60 rear axle. thanks in advance
1972 GMC C20 Custom Camper 350/TH350 |
Re: 1990s hubcaps for C20
Which caps? I'm running later 90s/00s GMC caps on mine but had to space the wheels out with 2 spacers in order to get the center hub to clear the cap. That in turn required longer lug studs.
That's the trouble spot, I think.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
this is what i want to run.
also is there any difference between the stock steel wheels on the 1996 and my 1972 other than the nubs on my stock wheels for dog dish style caps? i wanted to just get newer style caps and put them on but dont know if i need the newer rims also
Born Psycho
![]() Join Date: Feb 2001
order the hybrid lug nuts off ebay and get a set of dually center caps and you're set, i run them on my truck but since i'm using a 14 bolt rear diff the standard caps fit without any problem.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Are you using the 70s steel wheel or the newer steel wheels?
'91 was the last year hubcap, 76-91 style. It was also the last year for the typical steel wheel people refer to as steelies, which accepted hubcaps. In '88 GM introduced "Styled Steel Wheels" with "Center Caps", which is more a European style...just like rallye wheels. Hubcaps don't work with styled steel wheels. The 88-98 style center caps work with aftermarket wheels. On pre-88s and R/V series 88-91 you can use conversion lug nuts to mount the center caps. In '88 GM went to 14mm studs and the conversion lug nuts are 9/16" in the duplex design, as factory, to hold the center caps on using the same plastic mock lug nuts.
I know it's an '85, but I used the black center caps on d-hole steel wheels on my Jimmy. I used a hole saw to cut out the fronts I went the opposite direction with my '95 Suburban. I used 7" Ford Accurides with 76-91 hubcaps for a more retro look. I wanted a more trucky look I'm showing these to give examples of alternatives to hard to find and expense 69-72 hubcaps. If you get creative, there are many possibilities. I don't think the 76-91 style looks so bad on these trucks. Thy are a sharp looking hubcap and plentiful
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-13-2016 at 11:08 PM. |
Here is a couple pictures of my 71 C20 with Dana 60 rear. I run (widened) 90´s styled steel wheels. It came with the newer style center cap on the rear when I bought it. Later I found a pair more like the ones in the front but both fits the Dana 60 hub. Maybe that deeper style center caps comes from duallys as jerry moss said. These are Chevy but I´m sure there are GMC´s in the same style.
For lug nuts you will need this style: http://www.ezaccessory.com/GM_9_16_E..._p/98-0009.htm
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
One of the classiest wheel deals on this sight right there...in Sweden! It's true, the tall center caps came on dual rear trucks. I like the 88-98 style so much better than the next one. Smooth looks great and very easy to clean. I have a set of styled steel wheels to get widened and both Chevy and GMC sets of center caps in moth balls for a later day
thanks for all the info guys.
special-k, i really like the look of the suburban. i have a '93 and love it. might have to do a wheel swap there now 68 50th, those are exactly what i want. i love the look. i checked with the local junk yard and they want 65 for wheel, 35 for cap, and 25 for ing. ouch.. would not have thought that stock '90s wheel are almost as much as aftermarket.I am going to check at a pick-n-pull thats about an hour away sometime. should be a little cheaper.
#10 | |
#11 | |
EDIT: I edited out some of your post and forgot to saying I'm glad you like the look on the 'Burb. Go for it. Not such a hard look to come by. I had this set-up on my '92 K3500 first ...with GMC caps, of course. Originally rallye wheel color, same as original. I painted charcoal to go with work truck grille. Plans are to have original wheels widened and run 295/75s in a milder tread for good weather. The 255/85s are supposed to be my winter set. The trend has always been put newer wheels on older trucks. But, I like older trucks so much I like to go back for a a retro look. Also wanted to take the SUV in a more truck-like direction since that's what it is used for. It's more of a truck than most pickups out there.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-15-2016 at 07:05 AM. |
These are not in the 1990's but rather 2011, pretty cheap and still look unique.
