![]() Join Date: May 2016
Three on the Tree Problem
I have a 1970 Chevy C10 6 Cylinder 250 engine. I have always had a problem with the shift hanging up between second and third gear. I have even replaced the shift tube but it still continues to hang up. Has anyone out there had a similar issues? If so any help with this would be greatly appreciated. Many Thanks in advance.
![]() Join Date: Dec 2013
Re: Three on the Tree Problem
Have you replaced the shift linkage bushings ? Realigned neutral ? Checked gear lube in trans ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
I know this is not the proper way to fix your problem but years ago a friend showed it to me and it worked. Take a pair vise-grips and where the rods hook to the linkages that come out the tube, squeeze the two linkages together that the rods connect to with the vise-grips. I know it sounds like a jerry-rig fix but it worked for me.
http://67-72chevytrucks.com/vboard/s...d.php?t=215307
Check this out. Simple and it works. Your 3OTT can shift like butter.....
Wanda - 1969 C/10 LWB 250 I6 3OTT LWB>SWB |
