White wall cleaner?
What does everyone use to clean and protect your wide white wall tires?
Can't seem to find a lot of specific cleaners and Coker cleaner doesn't ship to Canada. |
Re: White wall cleaner?
Westley's Bleach White if they still make it.
The Coker reps suggest not using that bleach white. Guy told me just use simple green
#4 | |
https://www.dbtires.com/cleaningtips.html |
I have used SOS Pads for cleaning, fwiw,
Allen |
Simple green and grey scotch bright pads. No wesleys.
Comet household cleaner. It has bleach in it.
![]() ![]() Join Date: Nov 2008
Softscrub and an ordinary kitchen sponge.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
I've used sos pads on my harley white walls for years.
There are Coker dealers in Canada....maybe one of them carry the Coker cleaner?
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
#10 | |
Lol, Allen |
I used Wesleys religiously for 3 years on my Coker bias whites. Cleaned fantastically, but man did I ruin the rubber!! It dried the white walls terribly, and cracked them to death. Replaced them with radial wide whites, and now am just as satisfied with sos pads and window cleaner. Still have the Wesleys on the shelf, but these wide whites are just too damn expensive to ruin that way! Learned my lesson !
Meguiars has a great spray cleaner and it works fantastic on white walls and or lettering. spray on, wait about 1 minute and hose off. simple and clean.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
I have Diamond Back Radial whitewall tires on our '55 Chevy Sedan. Here is the link on how to clean them from their website. I've cleaned them according to their directions for over a year with no problems. I use simple green and a grey scotch bright pad. No problems yet.
"CLEANING TIPS (No Bleach) One of the first things you will notice is that Diamond Back Classics are extremely easy to clean. Most whitewalls turn dingy or yellow because of the leaching of chemicals (mostly anti-oxidants) into the white material. Because our process uses a butyl lining to stop chemical leeching, you only have to clean the surface dirt. We recommend frequent cleanings with an abrasive cleaning pad. A fine or medium sanding sponge works well. These are available at most hardware stores. Any good cleaner works OK - Castrol Super Clean, 409, Simple Green, Greased Lightning - just to name a few. Avoid cleaners that contain bleach. Prolonged use of these cleaners can “dry” the whitewall surface. Do not use products such as Armor All on whitewall. This could cause slight discoloration. Whitewall surfaces tend to “dry” with time, heat, ozone, etc. A vigorous cleaning periodically will get rid of the dry surface and help maintain the tire’s beauty. Don’t be afraid to scrub." http://www.dbtires.com/cleaningtips.html Tod59 |
![]() Join Date: Jun 2013
Mr Clean magic eraser
#15 |
Sos pads worked great on my Harley white walls
#16 |
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#17 |
Old Heap Driver
My experience with Coker's tire cleaner was a waste of time. The best I've used is a cleaner called "Awesome", it's available at Dollar Tree and Walmart.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
#18 |
Aluminum brightener works great. It is an acid so don't get it on your hands. If you are going to polish aluminum wheels use it first then polish them. It will clean all that mess off the tires also. You can find it at big truck chrome shops or by the gallon at air conditioning shops they use it to clean the coils.
My 55 Build 55 C-4 |
#19 |
![]() They work good even when really dirty.
http://img.photobucket.com/albums/v1...ps5d879c42.jpg Dean's 56 truck build. http://67-72chevytrucks.com/vboard/s...d.php?t=636474 |
#20 |
this! use it for the same reason and it works great
1959 Chevy Apache SWB Fleetside - 350 GM crate with mild cam, 700r4, 4.10 rear |
#21 |
Simple Green and a stiff bristle brush. If needed I break out a scotchbrite pad......
#22 |
Westley's Bleach white is still available and works GREAT
1950 GMC 1968 Olds 442 |
#23 |
I used SOS pad on my 51 Merc when I was 16 in 1963 and have used them off and on ever since when I had white walls on a rig. I've used bleach white at times but to me it didn't work any better and I used Simple green and a scrub pad on the last Cad that I had that had whitewall tires.
