Old 06-14-2016, 06:49 PM   #1
Badger69
Badger69's Avatar
LS Airbox
Thought I'd share my air box.
95-97 chevy truck under hood storage box with "ram air" opening in core support and temp sensor relocation.
'69 C10 | LS2 | 4L70e | 4 Wheel Disc Brakes | Accuair eLevel | 20" steel wheels | Porterbuilt goodies | Push Button Start | Tilt | Cruise
'79 Burbo | 2wd | 8100 Vortec/Allison swap | A/C | soon to be bagged.
Badger69 is offline   Reply With Quote
Old 06-14-2016, 09:48 PM   #2
solidaxel
solidaxel's Avatar
Re: LS Airbox
Double Duty, I like it!
Are these in all pick ups?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-14-2016, 10:36 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS Airbox
cool setup. Fwiw, thats called a "bellmouth"
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-15-2016, 12:36 AM   #4
Badger69
Badger69's Avatar
Re: LS Airbox
Thanks! I think they are in just about every truck and suv. Some of the diesel trucks had 2nd batteries in that location.
I really wanted to find something GM to use and this popped in my head.
Old 06-15-2016, 12:37 AM   #5
Badger69
Badger69's Avatar
Re: LS Airbox
I always called them turbo mouths because they are often seen on turbo cars. Bell mouth sounds better.
Old 06-15-2016, 01:13 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS Airbox
Especially if you run one on a supercharged car....turbo mouth wouldn't feel right
Old 06-15-2016, 07:53 AM   #7
solidaxel
solidaxel's Avatar
Re: LS Airbox
TODAY, find a truck box from a 95 to 97 Chevy truck !!
LS 3 4L70E
Old 06-15-2016, 09:13 AM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: LS Airbox
Killer looking ride. Love the stance.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-15-2016, 04:30 PM   #9
Badger69
Badger69's Avatar
Re: LS Airbox
Also added a gasket to the lid and a clevis pin to hold it tight.
Old 06-15-2016, 04:31 PM   #10
Badger69
Badger69's Avatar
Re: LS Airbox
Thank you. I am really happy with how it turned out.
Old 06-15-2016, 04:34 PM   #11
Badger69
Badger69's Avatar
Re: LS Airbox
Here is a shot through the grille.
Old 06-16-2016, 01:10 PM   #12
solidaxel
solidaxel's Avatar
Re: LS Airbox
What is the proper name of the truck box............. for ebay info
LS 3 4L70E
Old 06-16-2016, 01:45 PM   #13
72MARIO
72MARIO's Avatar
Re: LS Airbox
Looks like your using a custom rad with inlet outlet on the same side ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-16-2016, 11:50 PM   #14
Badger69
Badger69's Avatar
Re: LS Airbox
1995'96'97'98 1-Under Hood Storage Box Silverado Sierra and SUV
Daddydan717 is who I got mine from
Old 06-16-2016, 11:51 PM   #15
Badger69
Badger69's Avatar
Re: LS Airbox
You are right, same side, but it is s Griffin LS radiator without built in transcooler.
Summit racing. Couple hundred bucks
Old 06-17-2016, 10:01 AM   #16
solidaxel
solidaxel's Avatar
Re: LS Airbox
Thanks, I will try that
LS 3 4L70E
Old 06-24-2016, 05:50 PM   #17
roundhouse
Re: LS Airbox
heres mine
used the stock hose, with a K&N on the end.
sawed off the big empty square on the stock hose cause it was hitting the radatior
covered the hole with a data plate i took from a abandoned coal fired powerplant in Greenville SC
now gotta figure out how to get the AC compressor on
roundhouse is offline   Reply With Quote
Old 06-24-2016, 09:26 PM   #18
CJM72
Re: LS Airbox
I wonder if that box would make a nice home for the ECU and relays needed for my upcoming LQ9 swap? Seems like the right location for the typical truck harness. I remember this box in my 96 K1500 well!
CJM72 is offline   Reply With Quote
Old 06-25-2016, 06:44 AM   #19
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LS Airbox
Here is mine.
4" hole cut for the air to enter the box.
4" coupler to mount the ninty and box and K&N filter.
The caddy box with another 4" hole cut and coupler installed. I sealed off the factory opening.
Box installed with the ninty and a bracket I made.
This is how it looks done.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-26-2016, 12:35 AM   #20
Badger69
Badger69's Avatar
Re: LS Airbox
I'm sure it would. Would be a nice way to hide all that junk. I chose to use it as an air box so I could do the ram air thing. All of my electronics are under the seat with amplifiers, relays and the push button start box. It was just too much to squeeze in there and not stress the harness connections.
Old 06-26-2016, 12:37 AM   #21
Badger69
Badger69's Avatar
Re: LS Airbox
Originally Posted by Andy4639 View Post
Here is mine.
Nice set up. Very discrete.
Old 06-26-2016, 08:30 PM   #22
Andy4639
Old member
Andy4639's Avatar
Thanks,
That's why I like this site so much. People do some of the coolest easist stuff to make their rides personal.
