Ignition timing and cam Question,the good stuff
Hello everyone,
I have a 68 c10 swb with a sbc 350 with a muncie 4-spd shiften the gears. I have built this truck since I was 15, now in my old age at 20 I have realized some mistakes I made along the way. The motor is a 70 year, edelbrock performer intake, edelbrock electric choke carb 600cfm, headers, MSD HEI street fire dizzy, dual electric fan, roller rockers, comp cam XE274H . Cam specs: See attachment. I am trying to learn how to properly tune my motor because it is currently not running good. I recently realized that I cant just slap components together without any plan and expect them to work ![]() 1 st. I need to determine if the combination of carb, intake, cam, and Dizzy will work. 2 nd. How do I properly adjust my timing with setting the proper timing curve, advance, with the cam I have what full mechanical advance should I have and what advance at idle, and vacuum advance. Do I need a hotter coil or different dizzy? 3rd. How do I properly tune the carb. I have attempted jetting the carb numerous times but I feel that I need to figure my ignition out first. I also pulled and resealed my intake manifold to make sure I don't have a vacuum leak. replaced the sparkplug wires, added the heat protection sleeves near the header to save the boots from shorting out. I also wired my dizzy through a relay so it has straight battery power. Please excuse my terrible spelling I immigrated to CA from Germany in 07 Any suggestions or tips are already greatly appreciated. -Ben |
Re: Ignition timing and cam Question,the good stuff
i am sure you will have many answers to the questions you are asking, however i would start with setting the timing to 12-14 degrees static and have advance on the distributer of 22 degrees max . this needs to be all in by 3000rpm.without the vac advance connected.this giving 36 degrees advance.
the set up you have will work , re the carb just read the edelbrock manual , and i would imgine the factory jetting will be ok out of the box.i have dynoed many engines with the carb you have and 99% of the time for a not radical engine has been right on the money as far as fuel settings are good luck.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
#3 | |
Do you think the cam is to big or okay? |
carb settings are available from edelbrock on there web site.
re the cam it all depends on the application, i have used the same in a 55 chevy , with a 350 and alloy heads, it lights up the rear tyres.a liitle lumpy, thougth the manifold i would change to a rpm type.
simple way. lock out distributor. put timing at 36 degrees. remove edelbrock, throw in trash. install holley. install wideband. tune holley using the afr as a reference
I'm a Holley guy because they are so simple, but with that said, I have 3 Edelbrock carbs and they can be tuned to be as effective with some time. The wide band O2 a great idea, but not mandatory.
What cylinder heads do you have? How much compression? What converter and rear gear are in the truck? These things all have a bearing on how much advance you might need or the motor can tolerate. Do you have a way of checking total timing and RPM? A dial-back timing light is the best tool but you can do same with a harmonic balancer tape. Do you have the paperwork on the MSD distributor? It will tell you what springs, weights, and advance bushing were installed on the distributor for a baseline. Honestly, buying a book on Carbs and another on Distributor ignitions will be worth more than the cost and educate you much faster and more accurately than message boards.
