06-16-2016, 12:57 PM | #2376 |
Moderator
Re: What did you do to your truck today part III
Okay - I re-read the post and it alllllllll makes sense now. Thanks.
Ya, I had those on my 53.
06-16-2016, 01:23 PM | #2377 |
Got my new tires mounted this morning!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-16-2016, 09:10 PM | #2378 |
Fixed the steering clearance issues by using a shorter Allen screw no nut like the ones provided by Flaming River. Your supposed to use the short neck rack with Porterbuilt crossmember. The manual, quick ratio rack is long neck. My wheel is 1-1/2 to full turn.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
06-17-2016, 10:04 AM | #2379 |
Tire's look great on your truck TJ!
Yesterday Dwayne flared the 1/4" brake tube and got it ready to go, after work I slapped it back on last night. Seems to be dry and holding. I get side-tracked easily (and I hate brake fluid) so I jumper-ed the headlight switch (1 & 5 / black and white on MY 62) to have continual park lamps with head lamps on. While in electrical mode, I replaced the P.S. Back-Up Light assembly which was not working properly. Replaced all 6 exhaust manifold flange nuts with all-metal lock-nuts - and had to replace the P.S. doughnut gasket too. I'm still getting exhaust contact in rear suspension travel, so that will get fixed next week with it going back to Dwayne's for alignment. This morning, bright and early, after getting it back up on stands (hard with the static drop) me and my sweetheart bled the brakes. I also set the shift linkage adjustment so the recently repaired back-up lights come on at the right time. Blew the Gr@nt kit apart to see why I had erratic horn function (that sounds odd). Step 1 - Shortened the turn signal lever screw, and Step 2 - discovered I had the horn button plate in upside down (metal plate out); to quote the great Fred Sanford, "You big dummy!" I felt a test drive was in order before going to work. Found a pin-hole leak in the top rad tank so that gets soldered soon too... but we are doing good electrically and overall making significant headway. |
06-17-2016, 09:15 PM | #2380 |
Got my CPP 5" lowering springs installed. It's exactly what I wanted, but now I have to get c-notches. *Exhaust is getting fixed soon, too.
Before and after: |
06-18-2016, 12:38 PM | #2381 |
Bed on and wood base(white ash with teak oil) is in...next is motor switch and T5 then the southern cab .... that is a lot of bolts nuts and washers!
06-18-2016, 12:38 PM | #2382 |
It's whole again....for now...
06-18-2016, 07:19 PM | #2383 |
finally got some paint applied. coat of sealer and three coats of white for the stripe. not a lot of contrast between the grey sealer and white paint.
06-19-2016, 10:34 PM | #2384 |
Someone actually filmed my truck to use in a country music video this week. The group is called Southern Push. I hope they make it big! It'll be a couple months before the video gets done, but I'm looking forward to seeing it!
06-20-2016, 11:05 AM | #2385 |
Looks very nice. Do you have a build thread for this truck?
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
06-22-2016, 07:19 PM | #2386 |
Looks like a porn set when you don't read the post
06-24-2016, 12:18 AM | #2387 |
paint at last flowed very good I love to spray when it flows nicely
06-24-2016, 09:48 PM | #2388 |
Went to Tuttle's today to pick up my truck. Had a blast wrenching with Cole and hanging out at the shop for a couple of hours. Greg did a great job on the paint work and I'm happy with the splash pans we added to the back bumper. Cole got 99% of the bounce out of the PS door too.
Tweaked the carb settings and it's much better. Clay barred the bumpers and they are much better than they were from over spray. Then attempted it on the wear strips but with less success there. Felt so good having the FLOP hood done and back on the truck, Heather and I loaded up and went to the Youngwood VFD Car Cruise then over to the Frosty Shack for shakes. Got our first dash plaque for the year and for the truck. |
06-27-2016, 12:36 PM | #2389 |
Opened up the transmission to replace filter n gaskets.
Can you see the Robot? I also replaced the front and rear seals while I was in there, though to the naked, untrained eye, they did look perfectly fine. Interestingly, the filter clearly was doing its job before. Happy to have this done too. Weekend over.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
06-28-2016, 11:52 PM | #2390 |
06-28-2016, 11:56 PM | #2391 |
Had a few minutes this evening so I installed the new to me clock in my GMC.
06-29-2016, 11:58 AM | #2392 |
Asked my area pin stripe artist Tyler Elliot to lay down some lines on my 62
06-29-2016, 12:00 PM | #2393 |
So then he went in the cab and touched up the dash... before crowning it on the tailgate.
w o w was my initial response. |
06-29-2016, 02:17 PM | #2394 |
took a few parts to work to use the sandblaster
1961 c10 longbed - gone 1964 c10 swb |
06-29-2016, 03:46 PM | #2395 |
I picked up a newly rebuilt T5 transmission to replace my sm465. Can't wait to get her installed!
06-30-2016, 01:36 PM | #2396 |
Now the bed's been MADE - time to go bring it home
06-30-2016, 05:23 PM | #2397 |
06-30-2016, 07:29 PM | #2398 |
AT LAST THE CAB IS HOME !!!!!!!!!!!
Well this afternoon I finished work and headed straight to We weld in New Romney . To. collect my cab the guys down there did a great job and also put in etch primer for me . They also took me some pictures of the process mounted on the spit Once blasted they put it primer All loaded on the trailer ready to head home So on my journey home I called Rian and my mate Stephen from my bike club to come over with the offer of pizza , it works every time . So with Rian, Stephen and Trevor my neighbour who had arranged getting it blasted at mates rates , as he has the unit next door to We Weld , and another neighbour John from over the road, we lifted onto the chassis . Just love this picture So the next update will be showing some of the repairs . It's just finding the time that seems to be the problem at he moment , but more about that later .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
06-30-2016, 07:45 PM | #2399 |
What!! A '60 hood with the lines of a 62-66 hood! Did you do that yourself? If so any pics of the transformation?
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
06-30-2016, 09:56 PM | #2400 | |
I wish I could take credit for it but it's the work of one called FLOP - a car builder and metal sharpe'r in the Pittsburgh area. Mad skills. THANKS! |
