Old 05-14-2016, 09:59 PM   #26
projectking
projectking's Avatar
Re: '68 C30 Cummins swap
Out with the old in with the new.....well it's almost in!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 05-14-2016, 11:09 PM   #27
Jeff's bowtie's
Very nice I want to do this with my 68 later on down the road
Jeff's bowtie's is offline   Reply With Quote
Old 05-15-2016, 12:17 AM   #28
projectking
Do it!
BTW, your build is making me think twice about keeping mine 2wd!
67 Chevy C10 LWB
90 Mustang Gt
Old 05-15-2016, 04:01 PM   #29
projectking
Trying to get it where I want it so I can figure out the mounts, pretty tight fit!
67 Chevy C10 LWB
90 Mustang Gt
Old 05-17-2016, 09:42 AM   #30
j_cst_10
j_cst_10's Avatar
here is what I did for the mounts. Worked pretty well, however the engine in a 2wd set up is very tight and I spent a long time getting the engine sitting exactly where I want it (not easy with a 1300# engine). It fits with a little room to spare on the firewall and a little room to spare with the front cross brace.
Hopefully that truck has a high hump floor or you'll have some serious cutting to do. If it has a high hump, a 1" body lift gives you enough room to fit everything.
http://67-72chevytrucks.com/vboard/s...d.php?t=694686
j_cst_10 is offline   Reply With Quote
Old 05-23-2016, 01:05 PM   #31
projectking
Thanks for the link, your truck looks great!
It has a high hump and after removing the AC compressor I have it where I want it. I plan to build a factory style engine side mount and the '93 lower isolators.
For now it's on standby, wife had a baby boy on Thursday(our 3rd)!
67 Chevy C10 LWB
90 Mustang Gt
Old 05-23-2016, 08:47 PM   #32
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Congratulations on the new little one! Good luck getting any time to work on the C30 now!
Ryan
1969 Chevy milk truck
Old 05-24-2016, 01:32 AM   #33
projectking
Thank you!
I'll be at it soon enough.....the pile of parts is in my way!
67 Chevy C10 LWB
90 Mustang Gt
Old 06-18-2016, 05:20 PM   #34
projectking
Had a chance to fab the engine mounts out of 5/16" and 1/4" plate.
Hopefully will have the transmission mount done this weekend so I can wire and start the intercooler piping.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-18-2016, 05:24 PM   #35
projectking
Almost forgot, picked up an '84 CCLB dually frame for my disk brakes, was only $100 and scrapped what I didnt need for $25!
Came with a pair of these hoping I can find 4 more, polished up they would look pretty nice.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-18-2016, 05:37 PM   #36
projectking
double post
67 Chevy C10 LWB
90 Mustang Gt
Old 06-18-2016, 06:21 PM   #37
Jeff's bowtie's
Looks good I haven't done anything to mine lately but I did pick up a 91 dodge with 195k on it with a 5.9 5speed and 205 frame was rusted bad so one day
Old 06-18-2016, 08:04 PM   #38
projectking
Perfect, swap it while it's still apart. I'm on my back modifying the GM trans mount to work with the getrag wishing the cab wasn't in the way.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-18-2016, 09:12 PM   #39
57taskforce
All about them K’s
57taskforce's Avatar
This is cool! I build 12v 5.9s at work. I've built 2 in the last 3 weeks and have another block, head and crank at the machine shop as we speak. I've been thinking about building a nasty 12v for my K20. A one inch body lift is no big deal to me.
Tyler
Old 06-19-2016, 07:52 AM   #40
projectking
I didn't have to do a body lift, or any cutting. With engine on the crane I picked it up letting the transmission angle down, once it was past the crossmember I used a floor jack to raise it and roll slowly as the engine came down/in. Have to say I was surprised how well it fit in there(once the AC and heater box were removed). I plan to get the bracket to raise the compressor and I will probably end up flipping the exhaust manifold so it clears.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-19-2016, 11:53 PM   #41
vma1788
Subscribed! Great build. I really been wanting to do this but with a 1/2 ton i think the 12v is a bit much for the rails. 4bt motors are nice but real expensive as well.
vma1788 is offline   Reply With Quote
Old 06-22-2016, 03:33 PM   #42
projectking
Mounted the fenders and hood last night and did some mockup....
Dodge radiator is too tall by roughly 2" and the GM radiator is too wide for the first gen intercooler.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-22-2016, 07:01 PM   #43
j_cst_10
j_cst_10's Avatar
The hood will still close with the Dodge radiator if you still wanted to use that. I am running it.
Old 06-22-2016, 07:07 PM   #44
projectking
I had it in and it's 2" from closing, I'm guessing the slant nose is the culprit.
What did you do as far as the wiring, and were you able to use the stock voltage reg?
67 Chevy C10 LWB
90 Mustang Gt
Old 06-22-2016, 07:47 PM   #45
j_cst_10
j_cst_10's Avatar
Oh yeah, forgot about that being a '68.
Luckily those engines don't need much of a radiator to stay cool. They run cool to begin with. I'm sure a universal radiator would work fine.
Old 06-22-2016, 07:52 PM   #46
projectking
Just went back through your thread and saw your non intercooled and have a different radiator than I do.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-26-2016, 04:12 PM   #47
projectking
Finally able to get some time with the truck.....well sort of, removed the disc brakes from the dually stub and hoping to get everything swapped onto the '68. Also using the power steering and sway bar/braces.
67 Chevy C10 LWB
90 Mustang Gt
Old 06-27-2016, 12:08 AM   #48
COS399
COS399's Avatar
Nice project you have going. You will love the 12 valve after your done. Also, Congratulations on the new birth.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 06-27-2016, 08:56 AM   #49
projectking
Thanks!
67 Chevy C10 LWB
90 Mustang Gt
Old 07-02-2016, 07:10 PM   #50
projectking
Today was a great day to work outside, perfect temperature!
Finalized the disk brakes and swapped the gearbox/steering parts from the '84, got the core support cut and the intercooler and piping installed. Can't believe that I was able to use everything from the dodge and only had to trim the intercooler mounting tabs so they clear the headlights. Waiting on a custom radiator to be built and I should be able to fire it up next week, already bumped it over with the key!
67 Chevy C10 LWB
90 Mustang Gt
