Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 04-30-2016, 06:43 PM   #76
Frugalmeyer
Re: Parting - 1972 4WD Blazer
JayJayB
Not sure what the radiator fits. Not sure what it cost to ship. You should come by San Antonio and pick it up.
Frugalmeyer is offline   Reply With Quote
Old 04-30-2016, 07:34 PM   #77
6768chevylover
6768chevylover's Avatar
How much for the dana 44 front disc brake brackets plus shipping to 18337? Thanks- Mike
6768chevylover is offline   Reply With Quote
Old 04-30-2016, 07:36 PM   #78
undertaker72
undertaker72's Avatar
ill take fan shroud if petes not taking , and shipping to 84648 thanks
I aint nobody DORK
1972 Cheyenne super k10 swb 350 4speed posi hooks
1934 ford 3 window blown 355
1969 Camaro hugger orange hounds tooth
undertaker72 is offline   Reply With Quote
Old 04-30-2016, 07:38 PM   #79
undertaker72
ill take or get in line on one or 2 exhaust manifolds same zip
I aint nobody DORK
Old 05-01-2016, 01:33 AM   #80
Frugalmeyer
undertaker 72
One manifold has a corner broke off at the exhaust pipe bolt.
Old 05-01-2016, 01:41 AM   #81
Frugalmeyer
undertaker72
Ill take the shroud to check for shipping.
UPS?
Old 05-01-2016, 01:42 AM   #82
Frugalmeyer
6768chevylover
I am not pulling the axles apart. I would like to sell them complete.
Old 05-02-2016, 02:52 PM   #83
Frugalmeyer
undertaker72
Shipping costs are crazy. 75.00 ups - for the 11lb shroud.
Old 05-02-2016, 02:55 PM   #84
Krex
Hey do you have the side mount for the transfer case to the frame ?
Krex is offline   Reply With Quote
Old 05-06-2016, 01:17 AM   #85
Frugalmeyer
Krex
Yes I have the l brackets and hardware. 40.00
The prices plus ride and paypal fees.
Old 05-06-2016, 03:52 AM   #86
undertaker72
Originally Posted by Frugalmeyer View Post
undertaker72
I'm out , freight kills that deal I'm sorry
I aint nobody DORK
Old 05-20-2016, 01:28 AM   #87
Frugalmeyer
BTT
Radiator no leaks. 80.00
Fan Shroud w/one hole drilled in center top. 55.00
Front axle (3:73) complete with springs, linkage, and dampener 400.00
Rear axle (3:73) "Posi" complete with springs. 400.00
NP 205 Transfer Case 350.00
350 Transmission 200.00
Prefer pickup and not no ship heavy items.
Old 06-18-2016, 10:52 AM   #88
Frugalmeyer
BTT
Radiator no leaks. 65.00
Fan Shroud w/one hole drilled in center top. 45.00
NP 205 Transfer Case 275.00
350 Transmission 175.00
- Transfer and transmission together 400.00
4WD Engine Cross member 40.00
4WD Engine Perches SBC 20.00 Pair
4WD Suspension Brackets 85.00 (all pictured)
4WD Front Springs 50.00 Pair
4WD Rear Springs 50.00 Pair
- Front and Rear Springs together 85.00
Old 06-18-2016, 11:29 AM   #89
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'd take the radiatior if total cost w shipping (to NM 87107) can be done for $100. Thanks, Pete
Old 06-18-2016, 12:09 PM   #90
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Also interested in the steering (not Pitman) arm off the front suspension if available. Thanks.
Old 06-18-2016, 11:37 PM   #91
1972K20
1972K20's Avatar
Can I get in line for the items I have circled pending close-up pics?
1972K20 is offline   Reply With Quote
Old 06-19-2016, 12:05 AM   #92
tjsblazer
tjsblazer's Avatar
I am interested in the front steering stabilizer brackets / hardware. Could you get a close up picture of each end so I could see what you have?
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 06-19-2016, 12:07 AM   #93
1972K20
1972K20's Avatar
Also, interested in front shock mounts.
Old 06-19-2016, 12:18 AM   #94
Frugalmeyer
tjsblazer
no front steering stabilizer brackets or hardware.
Old 06-19-2016, 12:24 AM   #95
Frugalmeyer
DeadheadNM
No steering arm to sell.
Old 06-19-2016, 12:27 AM   #96
Frugalmeyer
1972K20
The circled items are the front leaf spring brackets. No front shock mounts to sell.
Old 06-19-2016, 12:45 AM   #97
tjsblazer
tjsblazer's Avatar
tjsblazer
Do you mean you don't want to sell them? In the picture with both axles it appears they are still on the front axle unless I am mistaken. The picture is zoomed pretty far out so I could be wrong.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-19-2016, 09:16 AM   #98
Frugalmeyer
tjsblazer
The front and rear axles listed on earlier posts have been sold along with any attached hardware. My post from yesterday lists what is still available and for sale.
Old 06-19-2016, 09:53 AM   #99
tjsblazer
tjsblazer's Avatar
tjsblazer
Sorry. My bad. I should have read through better.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 06-19-2016, 03:26 PM   #100
1972K20
1972K20's Avatar
Interested in bump stops. Also, sending you a PM with my info about the item I have circled here:
