Closed Thread
Old 06-16-2016, 12:57 PM   #2376
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: What did you do to your truck today part III
Okay - I re-read the post and it alllllllll makes sense now. Thanks.
Ya, I had those on my 53.
The Rocknrod is offline
Old 06-16-2016, 01:23 PM   #2377
TJ's Chevy
TJ's Chevy's Avatar
Got my new tires mounted this morning!
TJ's Chevy is offline
Old 06-16-2016, 09:10 PM   #2378
LVPhotos
LVPhotos's Avatar
Fixed the steering clearance issues by using a shorter Allen screw no nut like the ones provided by Flaming River. Your supposed to use the short neck rack with Porterbuilt crossmember. The manual, quick ratio rack is long neck. My wheel is 1-1/2 to full turn.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 06-17-2016, 10:04 AM   #2379
robber grin
Tire's look great on your truck TJ!
Yesterday Dwayne flared the 1/4" brake tube and got it ready to go, after work I slapped it back on last night. Seems to be dry and holding.
I get side-tracked easily (and I hate brake fluid) so I jumper-ed the headlight switch (1 & 5 / black and white on MY 62) to have continual park lamps with head lamps on.
While in electrical mode, I replaced the P.S. Back-Up Light assembly which was not working properly.
Replaced all 6 exhaust manifold flange nuts with all-metal lock-nuts - and had to replace the P.S. doughnut gasket too. I'm still getting exhaust contact in rear suspension travel, so that will get fixed next week with it going back to Dwayne's for alignment.
This morning, bright and early, after getting it back up on stands (hard with the static drop) me and my sweetheart bled the brakes.
I also set the shift linkage adjustment so the recently repaired back-up lights come on at the right time.
Blew the Gr@nt kit apart to see why I had erratic horn function (that sounds odd).
Step 1 - Shortened the turn signal lever screw, and Step 2 - discovered I had the horn button plate in upside down (metal plate out); to quote the great Fred Sanford, "You big dummy!"
I felt a test drive was in order before going to work. Found a pin-hole leak in the top rad tank so that gets soldered soon too... but we are doing good electrically and overall making significant headway.
robber grin is offline
Old 06-17-2016, 09:15 PM   #2380
Backpayne
Got my CPP 5" lowering springs installed. It's exactly what I wanted, but now I have to get c-notches. *Exhaust is getting fixed soon, too.
Before and after:
Backpayne is offline
Old 06-18-2016, 12:38 PM   #2381
canadian_diesel1964
Bed on and wood base(white ash with teak oil) is in...next is motor switch and T5 then the southern cab .... that is a lot of bolts nuts and washers!
canadian_diesel1964 is offline
Old 06-18-2016, 12:38 PM   #2382
canadian_diesel1964
It's whole again....for now...
Old 06-18-2016, 07:19 PM   #2383
luvmytruck
finally got some paint applied. coat of sealer and three coats of white for the stripe. not a lot of contrast between the grey sealer and white paint.Name:  20160613_110627_resized.jpg
luvmytruck is offline
Old 06-19-2016, 10:34 PM   #2384
Revoh
Revoh's Avatar
Someone actually filmed my truck to use in a country music video this week. The group is called Southern Push. I hope they make it big! It'll be a couple months before the video gets done, but I'm looking forward to seeing it!
1963 C-10
My car blog, for your reading pleasure.
Revoh is offline
Old 06-20-2016, 11:05 AM   #2385
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Looks very nice. Do you have a build thread for this truck?
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline
Old 06-22-2016, 07:19 PM   #2386
phillip123hastings
Looks like a porn set when you don't read the post
phillip123hastings is offline
Old 06-24-2016, 12:18 AM   #2387
luvmytruck
paint at last flowed very good I love to spray when it flows nicely
Old 06-24-2016, 09:48 PM   #2388
robber grin
Went to Tuttle's today to pick up my truck. Had a blast wrenching with Cole and hanging out at the shop for a couple of hours. Greg did a great job on the paint work and I'm happy with the splash pans we added to the back bumper. Cole got 99% of the bounce out of the PS door too.
Tweaked the carb settings and it's much better. Clay barred the bumpers and they are much better than they were from over spray. Then attempted it on the wear strips but with less success there.
Felt so good having the FLOP hood done and back on the truck, Heather and I loaded up and went to the Youngwood VFD Car Cruise then over to the Frosty Shack for shakes.
Got our first dash plaque for the year and for the truck.
Old 06-27-2016, 12:36 PM   #2389
Grizz1963
Grizz1963's Avatar
Opened up the transmission to replace filter n gaskets.
Can you see the Robot?
I also replaced the front and rear seals while I was in there, though to the naked, untrained eye, they did look perfectly fine.
Interestingly, the filter clearly was doing its job before.
Happy to have this done too.
Weekend over.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 06-28-2016, 11:52 PM   #2390
TJ's Chevy
TJ's Chevy's Avatar
Thanks man!
Old 06-28-2016, 11:56 PM   #2391
TJ's Chevy
TJ's Chevy's Avatar
Had a few minutes this evening so I installed the new to me clock in my GMC.
Old 06-29-2016, 11:58 AM   #2392
robber grin
Asked my area pin stripe artist Tyler Elliot to lay down some lines on my 62
Old 06-29-2016, 12:00 PM   #2393
robber grin
So then he went in the cab and touched up the dash... before crowning it on the tailgate.
w o w
was my initial response.
Old 06-29-2016, 02:17 PM   #2394
joe dirt
joe dirt's Avatar
took a few parts to work to use the sandblaster
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline
Old 06-29-2016, 03:46 PM   #2395
Backpayne
I picked up a newly rebuilt T5 transmission to replace my sm465. Can't wait to get her installed!
Old 06-30-2016, 01:36 PM   #2396
robber grin
Now the bed's been MADE - time to go bring it home
Old 06-30-2016, 05:23 PM   #2397
chevy2tom
chevy2tom's Avatar
w o w
Awesome work
chevy2tom is offline
Old 06-30-2016, 07:29 PM   #2398
mjh1965
mjh1965's Avatar
AT LAST THE CAB IS HOME !!!!!!!!!!!
Well this afternoon I finished work and headed straight to We weld in New Romney . To. collect my cab the guys down there did a great job and also put in etch primer for me .
They also took me some pictures of the process mounted on the spit
Once blasted they put it primer
All loaded on the trailer ready to head home
So on my journey home I called Rian and my mate Stephen from my bike club to come over with the offer of pizza , it works every time . So with Rian, Stephen and Trevor my neighbour who had arranged getting it blasted at mates rates , as he has the unit next door to We Weld , and another neighbour John from over the road, we lifted onto the chassis .
Just love this picture
So the next update will be showing some of the repairs . It's just finding the time that seems to be the problem at he moment , but more about that later .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 06-30-2016, 07:45 PM   #2399
62stepside longbox
62stepside longbox's Avatar
What!! A '60 hood with the lines of a 62-66 hood! Did you do that yourself? If so any pics of the transformation?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline
Old 06-30-2016, 09:56 PM   #2400
robber grin
So far I weld a bit but I'm not a welder just yet. Having said that it was a vision I had many years ago that I had held on to until I met a guy that I thought could do it.
I wish I could take credit for it but it's the work of one called FLOP - a car builder and metal sharpe'r in the Pittsburgh area. Mad skills.
THANKS!
Closed Thread
