Old 06-22-2016, 08:10 AM   #1
86er
86er's Avatar
Jimmy is home
I am very happy with my new ride, got it running last night after sitting 14 years in a garage,,,,
starting on the brakes tonight, there a mess, here is a few pics.
86er is offline   Reply With Quote
Old 06-22-2016, 09:12 AM   #2
68panelman
68panelman's Avatar
Re: Jimmy is home
Looks great!!!
68panelman is offline   Reply With Quote
Old 06-22-2016, 09:47 AM   #3
mrtoni
Re: Jimmy is home
What am I missing? Pics?
mrtoni is offline   Reply With Quote
Old 06-22-2016, 10:33 AM   #4
buckkoo
buckkoo's Avatar
Re: Jimmy is home
Sweet ride
buckkoo is offline   Reply With Quote
Old 06-23-2016, 06:50 AM   #5
86er
86er's Avatar
Re: Jimmy is home
not sure why i can't post pic's.....sorry i will try later.
Old 06-23-2016, 06:53 AM   #6
86er
86er's Avatar
Re: Jimmy is home
Old 06-23-2016, 06:55 AM   #7
86er
86er's Avatar
Re: Jimmy is home
72
Old 06-23-2016, 07:03 AM   #8
86er
86er's Avatar
Re: Jimmy is home
72
Old 06-23-2016, 07:07 AM   #9
86er
86er's Avatar
Re: Jimmy is home
gmc
Old 06-23-2016, 07:13 AM   #10
86er
86er's Avatar
Re: Jimmy is home
need to work on the brake,,,,for there is none...
can't seam to find and front rotors ,,,,any help .i checked local store's none available..
Old 06-23-2016, 09:44 AM   #11
bambbrose
Active Member
bambbrose's Avatar
Re: Jimmy is home
Beautiful rig. Great work! Doesn't look like it has been sitting long.
bambbrose is offline   Reply With Quote
Old 06-23-2016, 09:46 AM   #12
68panelman
68panelman's Avatar
Re: Jimmy is home
Looks great!
Old 06-23-2016, 10:05 AM   #13
86er
86er's Avatar
Re: Jimmy is home
14 year inside...
Old 06-23-2016, 10:06 AM   #14
86er
86er's Avatar
Re: Jimmy is home
i can't find the front rotors anywhere..........need some help...
does the hub go with the rotor ?
Old 06-23-2016, 11:31 AM   #15
Mick54615
Re: Jimmy is home
I found mine at Summit. Drilled and slotted for about $50 each.
Mick54615 is offline   Reply With Quote
Old 06-23-2016, 11:52 AM   #16
86er
86er's Avatar
Re: Jimmy is home
really i will look again,,,
are they just a regular rotor,,,,,because i need the rotor with the hub neck..
unless i just need to beat it off there, seamed like it was one piece
Old 06-23-2016, 11:57 AM   #17
A1971Blazer
A1971Blazer's Avatar
Re: Jimmy is home
Two piece......knock the studs out..it'll come apart...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-23-2016, 11:58 AM   #18
86er
86er's Avatar
Re: Jimmy is home
cool i found them.......thanks......
Old 06-23-2016, 12:55 PM   #19
1rippen6
Re: Jimmy is home
From the picture it looks like you have a lot of meat left on them you sure you can't just get them turned. Any shop that can turn them should know the spec.
1rippen6 is offline   Reply With Quote
Old 06-23-2016, 04:23 PM   #20
JMac11
JMac11's Avatar
Re: Jimmy is home
Technically the lugs a pressed/swedged in through the hub. I know 1000's are knocked out and back it and it rarely causes a problem. CHeck for run out/ wobble before you finish assembling the unit
JMac11 is offline   Reply With Quote
Old 06-23-2016, 09:27 PM   #21
A1971Blazer
Re: Jimmy is home
There's a heavy knurl on the shoulder that swedges the hole in the rotor and hub at the same time.......... I have reused old studs but usually where maybe just one breaks and I don't pull the disc off the hub. Just knock in a used one and go.
When I replace the disc...I put new studs in and press each one a little at a time.........that centers the disc and hub.....
1967 C10 Step side
1968 C10 Step side
Old 06-28-2016, 06:45 AM   #22
86er
86er's Avatar
Re: Jimmy is home
brakes are done....just waiting on one rear rotor, then bleed them ,,,,
can't wait to drive it. taking it to the Good Guys show this weekend....
Old 06-28-2016, 08:00 AM   #23
71swb4x4
71swb4x4's Avatar
Re: Jimmy is home
Looking good!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
