06-18-2016, 09:23 PM | #1 |
Senior Moment
Anybody run stand alone systems to run their LS
Anybody run stand alone systems to run their LS like FAST, Holley or Edelbrock
If so which one and how did you like it. I just installed my LS1 and I'm thinking on FAST?. Thanks in advance Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
06-18-2016, 09:27 PM | #2 |
Senior Moment
06-19-2016, 02:45 AM | #3 |
meowMEOWmeowMEOW
Re: Anybody run stand alone systems to run their LS
IMO most of the time those standalone systems don't net you anything that the standard ECM system wouldn't. I've used the Fast, Econtrols, and I've spent about 20 minutes with the Holley. For some swaps with really unusual configs they are cool, or to do things like double injectors, ITB's etc.
You get away with a few less wires, but the cost is pretty high. The FAST and eControls tune well, with the FAST being more of a user-friendly thing and eControls being a more works-for-anything system.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
06-20-2016, 09:14 AM | #4 |
What about using a Marine Electronic Fuel Injection GM unit?
Is the cost the same or more than a stock ECM, what about the harness?
06-20-2016, 01:12 PM | #5 |
meowMEOWmeowMEOW
I don't think you can run a VSS on that, so controlling an auto trans or speedo would be interesting. Which actually makes me wonder....how do boats know how many knots they are going?
06-20-2016, 01:47 PM | #6 |
Boosted Member
Nope. Nobody. You'll be the first.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
06-20-2016, 02:48 PM | #7 |
VSS is alot less important without an electronic trans...I had LT1swap program my PCM for a manual trans and I have not hooked up a VSS yet, knocking down 20 MPG with my 5.3
06-20-2016, 09:25 PM | #8 | |
Senior Moment
06-21-2016, 12:47 PM | #9 |
I used an MS3-Pro on my truck. It was definite overkill for a stock 4.8, but I was using it to develop a custom wiring harness. Here's my take on what situations a stock ECU would be a good fit for, and what ones would call for a standalone.
Stock engine? Stock ECU makes perfect sense here; you don't really want much in the way of tunability. A couple minor bolt ons or a cam swap? It shouldn't be too hard to adjust the stock ECU for this. Forced induction or a serious naturally aspirated build? OK, this is starting to get to the point where you will want to look at standalones. You might be able to tune a stock ECU to run this. However, standalone ECUs are often a bit simpler to tune under boost (no weird MAF trickery, for example) and give you access to features like the individual cylinder trim tables. A lot of those settings in a stock ECU are hard to access and often wrong for a turbo or all out build. You could add more fuel across the board to compensate for a lean cylinder, but that would leave power on the table. Another good reason to start looking at standalones is if your build calls for a lot of black boxes for features a stock ECU can't easily do - standalones have a lot of race features as standard equipment. I've heard of tricks to sort of get boost control out of a stock ECU, for example, but not to make one do closed loop boost control that ramps in the boost on a timer after you release a two step rev limiter, or ones that will let you creep forward on a trans brake. (Stock ECU gurus, feel free to chime in if there is a trick to do this.)
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
06-21-2016, 02:21 PM | #10 |
Most boats have paddle wheels that measure the water speed (which can be inaccurate on a river) and/or GPS based speedo's.
06-22-2016, 11:11 AM | #11 | |
Boosted Member
I tuned my old LSx jet boat with a manual trans segment in the ECM. It was one of the easiest tunes I've ever done, as there is no transmission, and you never go up or down hill, so the RPM vs MAP is one straight angled line, basically a 2D map, versus a true 3D map like in a car.
06-22-2016, 11:26 AM | #12 | |
Senior Moment
06-22-2016, 06:40 PM | #13 |
I am thinking most run these on their non LS motors...It should work cause some carb their LS motors...
71 C10 I6 250 TH350 power steering and power breaks... |
06-23-2016, 10:08 AM | #14 |
I'm not running one, and I don't have an LS (yet) but I've been looking into them and from what it sounds like, none of them control the transmission, or if they do they are expensive. You'd likely need a stand alone trans controller for it. If you don't have a computer controlled trans, this wouldn't be an issue though.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
06-25-2016, 03:47 AM | #15 |
I know people that use Holley on everything. That is what they are using in NHRA pro stock now as well.
06-27-2016, 09:28 AM | #16 | |
Boosted Member
I know the Megasquirts can also do auto trans control via a separate box that is CAN bussed to the MS.
06-27-2016, 10:25 PM | #17 | |
In the old days, people spent big bucks and effort building a shortblock and adding quality cylinder heads. Now a cheapo junkyard LS is typically good to go with minor upgrades (valvesprings, pushrods, etc) and the money is spent on engine management.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
06-28-2016, 01:56 AM | #18 |
It's strange that the Holley system was actually in an R and D stage back in 2000-2001. I was part of a pro stock truck team that was testing it when the class was axed. The Holley stuff has come a long way since then. Grumpy Jenkins had 1 truck that raced with it at the time and that was Victor Cagnazzi.
06-29-2016, 02:51 PM | #19 | |
Boosted Member
06-29-2016, 07:39 PM | #20 |
To be honest I don't know. Tom Jenkins was the race rep at Holley and decided to get the team I was involved with to R and D. They wired a truck and installed all the ignition and software. This unit was 1 coil per cylinder and used a lap top and had the same tuning software ideas as the new Dominator. We had the fuel injection from them as well but never tested it. The truck had the original MSD in it as well because the Holley was a test. 1 day the truck fired and blew up the intake on its own!! Seriously it was parked in the shop with nobody around and kabloom. Everthing was sent back to Holley. That was the cost of testing a new product so both parties could learn. The new stuff does not require 8 coils and seems to be really reliable. A lot of people I know use it and prefer it. They all are using power adders now so I am positive Holley fixed the problem. The fuel injection that we were supposed to test in 01 but the class was axed. So 15 years later it made its way into pro stock. This software was ahead of its time with the tunability it offered . Individual cyl timiming, and timing changes on gear changes was really a good idea. It's really helpfull with nitrous tuning Lol
06-30-2016, 08:31 PM | #21 |
I'm using a stand alone harness for my LY6 and tr6060 made by Modern Vintage Performance in Indiana. The quality is amazing, the customer service is fenominal and it looks awesome.
06-30-2016, 11:08 PM | #22 | |
meowMEOWmeowMEOW
What your referring to is a custom harness, which is sometimes called a stand alone harness, meaning "not part of the factory wiring". Just so everyone is kinda on the same page.
