Junior Member
Arg!!!!!!!!
I need some of your expert advice. I know I saw the answer here, but now I can't find it! ![]() let me start with the begining. After my truck sat for the Pennsylvania winter, I noticed while I had it out today that the rear breaks want to lock up too fast. Just stopping from about 25 MPH, so it's not like I'm standing on the pedal. I pulled the driver side drum, and although it was dusty, the shoes aren't bad, (only about 600 miles, and they worked fine last summer! This leads to question #2: I can't remember how tight to make the 2 "ring" nuts, the ones that hold the drum on to the rear end, and also, hot tight do I torque the 8 bolts that hold the axel to the drum? it's a '67 3/4. Sorry about the long post! Dave ![]()
67 C-20 LWB 56 Nomad--- nope, sold it ![]() 75 Stingray 13 Silverado crew cab 08 Trailblazer (wife's) ![]() Pittsburgh, PA |
I suspect that your brakes are fine, they likely just need some use to get back to their old selves. I hope someone can better answer your torque questions.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
Junior Member
thanks, jku....
The service manual doesn't even mention this set up, but I knew it at one time. I guess memory IS the 2nd. thing to go! (Can't remember the 1st.!)
member #16
![]() Join Date: Dec 1999
Heres the bearing adj. from timken
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Junior Member
And thanks John!
I did find the specs in the service manual after my first post. Lesson learned, never tear into your rear end AFTER a hard day at work! ![]()
