Old 06-14-2016, 08:38 AM   #1
38932
4L60 Cooler Lines
In process of completing an LS swap in my '65 C10. I need to make the trans cooler lines. I have the original fittings with new o rings and clips installed but the steel lines have been cut. So I have the factory connection on the trans with 2 steel lines that have been shortened.
Can you use barb fittings and rubber hose to complete the connection to radiator? Or does it require AN type connection?
38932 is offline   Reply With Quote
Old 06-14-2016, 04:34 PM   #2
michael bustamante
michael bustamante's Avatar
Re: 4L60 Cooler Lines
i dont think theres too much fluid pressure in the lines. im using the stock lines with an aftermarket cooler and will be using short rubber lines to complete the connection
1967custom
michael bustamante is offline   Reply With Quote
Old 06-14-2016, 06:08 PM   #3
38932
Just wondering if the pressure requires AN type connection. I might try an after market cooler as well. Thanks for the info.
Old 06-24-2016, 08:51 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 4L60 Cooler Lines
I have the stock fittings on the 4l80e transmission but have regular rubber tubing going to the radiator and aux cooler. 3 years now! No problems.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-30-2016, 09:04 PM   #5
tony2tall
I used compression fittings to "tap into" to the stock lines. After that barb fittings and rubber hose. These are parts Derale uses in their trans cooler kits.
tony2tall is offline   Reply With Quote
