Old 06-27-2016, 09:29 AM   #1
Caddylackn
Caddylackn's Avatar
What is the stock rim for a 1969 C-20 Custom Camper
The wheels and tires it came with are 9.5 R 16.5. Steelies with hubcaps.
My spare looks to be original Firestone nylon and it is a 7.5 R 16 that is a split rim. What did this truck come with stock?
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 06-27-2016, 10:56 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: What is the stock rim for a 1969 C-20 Custom Camper
3/4 ton 2WD trucks required 7.50X16 8 ply rated tube type tires, 8.75X16.5 8 ply rated tubeless tires (if GVW did not exceed 7000#) or 9.50X16.5 8 ply rated tubeless in order to qualify for the Custom Camper nameplate according to info on the GM Heritage Center website. All were bias ply. So both of your sizes are "correct". The SPID in the glove box, if there, should list the optional tire size.
Off the top of my head, I'd bet yours came with 9.50X16.5.
FirstOwner69 is offline   Reply With Quote
Old 06-27-2016, 03:01 PM   #3
Sicklajoie
The Niner
Sicklajoie's Avatar
I would say 9.50X16.5 also. If the SPID is still on the inside of the glovebox door it should say what size.
I have a 69 C/20 Custom Camper also and currently run 265/75/16 Michelins on 16 x 7 F#rd van rims (same bolt pattern and same nubs for hubcaps). The only difference with F#rd rims are they're lug centric, not hub centric.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 06-27-2016, 04:35 PM   #4
Caddylackn
Caddylackn's Avatar
The Tire size is not listed on the SPID. Truck is rated 7,500 GVW. I like the steelies and hubcaps look, but would prefer the 16" rims to make tires easier to find. Thinking about running 285/75/16 tires in the rear with the stock 4:11 gears to make highway speeds more feasible. I will look out for some of the Ford Rims. Didn't know these would fit chevy hubcaps.
Thanks for the responses.
