Door handle fit
Does anyone know if this is normal? Just looks like to big of a gap. Driver side is perfect.
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=706924 |
Re: Door handle fit
door handle gap
Re: Door handle fit
that is not right mine fit tight as a glove
Re: Door handle fit
Are you reinstalling a handle that was already on or is it a different one?
Is the plunger rod too long holding it out? Sometimes on the rh side the rod need shortened a bit because it is a shared part with a Suburban rear door. Just guessing. Would need to see a picture.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
Re: Door handle fit
It's touching on the right side so I would think it's not the rod. These did come off another truck. I'm trying to figure out if maybe this door isn't original or had some work done to it.
![]() Join Date: Oct 2011
Re: Door handle fit
is it a '67 handle? I know they're different. but I don't know how/if they fit in a newer door....
if I was home I could post a pic of each.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
Re: Door handle fit
They are both the same so if they didn't fit then the driver side shouldn't have I would think.
Re: Door handle fit
Looks to me like the opening in the door is bent in.
1972 Dark blue, Cst, Highlander |
Re: Door handle fit
Re: Door handle fit
Thanks guys. I don't know what I need to do about that. May just have to roll with it.
Re: Door handle fit
dont just roll with it water will get in and mess sh!t up rust etc
i would pull it of and go at it from inside of the door with a wooden end of a hammer and tap the hammer lightly and slow till it levels out don't do it in one shot super light taps even if it take a hundred and it should bend out without damaging your paint (the end of a broom handle cut off would work too) |
Re: Door handle fit
Ok. I was worried about the paint chipping if I started hitting on it.
Re: Door handle fit
How did the original handle fit or was it missing ?
Re: Door handle fit
Original handle was gone.
#15 |
Re: Door handle fit
Get behind it and try to push it out. Avoid hitting the very edge and you shouldn't chip.
