Old 06-27-2016, 10:56 PM   #1
aod92
aod92's Avatar
Code po332
My truck has a po332 code which is for a knock sensor. My knock sensors are new and My motor has never gotten wet so I know that's not the problem. I do notice my truck makes a lot of lifter noise. Could that be causing a false reading? My truck also seems to be sluggish. Would this cause a low power problem? My truck just has a base tune in it and I'm bringing it to be tuned in the next couple of weeks. I want to get these bugs worked out before it hits the dyno
aod92 is offline   Reply With Quote
Old 06-27-2016, 11:49 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Code po332
False? We don't know its false yet, you might actually have knock....
How bad is the lifter noise, and did you do heads/cam or something like that? If you have noisy lifters (beyond the normal "ls motors are noisy" level), then you probably have a mechanical problem. Ruling out a cause of knock while an actual defect exists won't get us anywhere.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-28-2016, 03:46 AM   #3
truckdude239
truckdude239's Avatar
Re: Code po332
I just went though thiz on my suburban . I replace my knock sensors when I did my intake gaskets using bwd sensors from Advance Auto Parts a new harness from Dorman. About 3,000 miles I have my check engine light come on for the p0332 knock sensor too low signal + short. I had to put my intake back off and I replace the knock sensors with the OEM Delphi and new harness harness. So far it has not come back I found out that the aftermarket knock sensors not that great
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
Old 06-28-2016, 07:17 AM   #4
aod92
aod92's Avatar
Re: Code po332
Brew city it does have a cam. Truck dude, those are the same knock sensors I used. Where do you buy the Delphi sensors...Dealer only?
Old 06-28-2016, 09:24 AM   #5
truckdude239
Re: Code po332
No i ordered them from advance auto made them warranty them out it took them about a week to get them they where actlay cheaper then the bwds i bought the dephi number is AS10017 i paid 46 for them where are the advance brand was 56 each, i made them warranty the knocks sensors the harness and intake gaskets when i redid mine. but i also have a comerical account so they wanted to keep me happy, but it would not be unreasonable for a walk in customer to ask for all that to be warrantied out
David fuller
2012 Subura outback
1999 honda accord
Old 06-28-2016, 09:29 AM   #6
truckdude239
Re: Code po332
https://www.amazon.com/Delphi-AS1001...n+knock+sensor
heres an even better deal
David fuller
2012 Subura outback
1999 honda accord
Old 06-28-2016, 10:31 AM   #7
aod92
aod92's Avatar
Re: Code po332
Originally Posted by truckdude239 View Post
Awesome. Thanks man
Old 06-28-2016, 10:38 AM   #8
Hart_Rod
Hart_Rod's Avatar
Re: Code po332
You may need to adjust the Knock threshold in the tune do to the cam and headers...
Hart_Rod is offline   Reply With Quote
Old 06-28-2016, 11:20 AM   #9
aod92
aod92's Avatar
Re: Code po332
That's something my tuner can do correct?
