Old 01-11-2016, 07:38 AM   #1
bealaddison
bealaddison's Avatar
Suburban Body Lift??
Hey guys, I have an '87 Suburban with 6in lift and 37" tires. They fit pretty decent, but when flexing they are getting into the fenders. I am trying to decide which way to go to keep them out of the fenders. I have a 3" body lift that I have already purchased. I also have a set of Zero Rates. I have not installed either yet.
I was wondering if I could get a way with just doing the Zero Rates and using them to push the front axle ahead enough to keep them out of the fenders? Or should I just bite the bullet and put the body lift in? Or will I need to do both?
I have no problem with doing either one, so I really don't want to hear a pros and cons debate, just looking for pictures.
If you guys could post up pictures of trucks, blazers, or suburbans with either a body lift, zero rates in front to move the axle ahead, or both it would be greatly appreciated.
Thanks!
'87 Chevy V20 Suburban
6in Lift, 37in Toyos/Nittos on 17x9 KMC Diesels
2009 Chevy Silverado 2500HD
6in Lift, 35in Toyos on 20x9 KMC Monsters
bealaddison is offline   Reply With Quote
Old 01-11-2016, 10:23 AM   #2
slotard
Re: Suburban Body Lift??
If I was in your shoes I'd move it forward and trim. 3" is a lot of body lift.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-11-2016, 11:59 AM   #3
bealaddison
I trimmed on my K5 and I hate the way it looks. Trimming will be a last resort. I was hoping for some first hand experiences.
Old 01-11-2016, 01:17 PM   #4
Front Range
Front Range's Avatar
35" tires.
Section the fender and expand/lengthen the rear half of the wheel well arch. It needs to move a few inches toward the cab.
Body lift - watch your body to chassis connections / linkages and Center Of Gravity
Fender Trim = The lower fender now has a gap between inner & outer skin = rust in the lower fender and front of the rocker over a period of several years.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 01-11-2016, 08:29 PM   #5
bealaddison
I am more looking for pics of each setup. Not really interested in advice or a how to thread. I'd just like to see pics of squarebodies that have either a body lift or the axle moved ahead with a Zero Rate setup.
Old 01-12-2016, 01:13 AM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
I wouldn't go above 1 inch body lift. 3 inch Body lift is too much and adds stress to the frame when flexing.
http://www.bushwacker.com/fender-fla...product-detail
Rich
1972 K5 Blazer CST Click HERE
Old 06-28-2016, 08:51 PM   #7
bealaddison
Any other pics of Suburbans with body lifts? Or people with experience with moving the axle ahead with Zero-Rates?
