06-28-2016, 03:15 PM | #1 |
Back end comes around under panic braking.
Hi All,
I can't keep my truck straight under hard braking. The backend comes around really aggressively. It's a 71 with power brakes in the front and drums in the back. Longbed. Posi-traction. It also has a trailer assist brake installed. The brakes have been inspected and pads replaces recently. New master cylinder also. Any ideas about what to look for? Thanks, Jeff |
06-28-2016, 03:50 PM | #2 |
Re: Back end comes around under panic braking.
Did you set the pin on the combination valve?
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
06-28-2016, 05:15 PM | #3 |
My '71 GMC did the same thing, rear end always came around to the right. R.R brake adjuster was was stuck. Freed it up, adjusted drums and it'll lock all four and stop pretty straight now.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
06-28-2016, 08:40 PM | #4 |
The rear brakes are not coming on. It's the rear brakes that keep you straight when you brake. So I would check the metering block. I am assuming you have disc front when you say power front. So you would need a metering block. Metering block holds pressure off the discs a bit until a certain pressure. But the 71 might have a combo valve. Anyhow I would verify correct parts and setup. Someone could have changed some brake components.
White K20 |
06-28-2016, 08:56 PM | #5 | ||
"I ain't nobody, dork."
Are the rear drums locking up? Could have gear oil leaking past the outer axle seals and if it gets into the drums it makes the shoes stick to the drums when the brakes are applied.
Gary
06-28-2016, 09:21 PM | #6 |
Find a dirt road or parking lot that is level, go about 10 mph or so and hit the brakes hard enough to skid to a stop and park right there. (Looseness of the dirt/ traction will dictate speed.) You want to get out and see which front brake locks up first, if you went to fast your back tires will pass up where your fronts engaged and erase the starting point of the fronts. If both start to skid close to the same place then go a little faster so you can get the rears to lock up and see if they both start skidding at the same place. You can rule out or confirm a non working wheel or whole axle this way.
06-28-2016, 09:51 PM | #7 |
I'm no expert and I don't play one on tv either but I remember in my younger days we used to jerk up on the parking brakes in our cars and spin them around 180 degrees. I'd be thinking rears are locking and fronts not so much. Try that dirt road skid suggestion that will tell you what's going on.
06-29-2016, 08:59 AM | #8 |
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
06-29-2016, 02:57 PM | #9 |
Thanks for all of the suggestions, guys. I have some research to do. I'll do the skid tests and let you know what I find.
As for the prop valve, yes I think it's the right part and has been set. The dash light does not go on, and I know the dash light works. The reason I have a new master cylinder is that the light was always on. The master cylinder was leaking out of the one of the pistons, not sure which. That was replaced, and I assume the prop valve sender was reset, since now the dummy light isn't on. But worth checking. But that's why I mentioned the trailer brake assist. There's a brake line splice off of the rear brake line for the trailer assist. I wonder if that isn't causing some issues. I plan to remove it. I should do that now and see if it helps. |
06-29-2016, 03:21 PM | #10 |
Air still in the system after the MC swap?
06-29-2016, 03:33 PM | #11 |
What ? You mean your almost 50 year old truck didn't come with ABS . Heaven forbid !
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-29-2016, 03:42 PM | #12 |
LOL. In 1993 I bought my first truck with ABS and two weeks later I had a major panic stop and was amazed to see ABS actually works!
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
06-29-2016, 03:49 PM | #13 |
Try the same truck in ice and see how that works for ya ?
06-29-2016, 05:28 PM | #14 |
Nothing works on ice but experience. Been in Georgia for 27 years and have probably lost my snow and ice driving talents!
