Old 06-29-2016, 10:24 PM   #1
Ruscal
Re: What would you do with a bent crossmember in the rear
I found a couple of pics, but no good ones of the completed xmember. It is made from 1x3x1/8". I expanded the ends to match the frame channel ID. Threaded inserts were welded into the ends to match up to the existing frame bolt holes. I fabbed the custom hitch to tie into it adding a little strength.
RC
Ruscal is offline   Reply With Quote
