Old 06-29-2016, 10:25 PM   #1
Harley03joe
A/C Dryer ??
My Question Is What Side On The Dryer Is The IN Side ? Right Side Or Left Side
Picture Below For The Help, Also How Much Fron Goes In The System
Thank You
Harley03joe
Harley03joe is offline   Reply With Quote
Old 06-29-2016, 11:47 PM   #2
truckdude239
truckdude239's Avatar
Re: A/C Dryer ??
Im goinv go go with the right side as the in side since it has in stamped on top there
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-30-2016, 12:56 AM   #3
Harley03joe
Re: A/C Dryer ??
Problem Is I Don't Know If It Was Replaced The Right Way ?
But Thank You For Your Answer
Harley03joe
Old 06-30-2016, 12:59 AM   #4
69chevytrucker
69chevytrucker's Avatar
Re: A/C Dryer ??
its right comes from the cooler and goes to firewall
69chevytrucker is offline   Reply With Quote
Old 06-30-2016, 08:17 AM   #5
Bigdav160
Bigdav160's Avatar
Re: A/C Dryer ??
Flow is from the compressor to the condenser, through the drier, to the expansion valve/evaporator.
It looks like it's connected properly
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-30-2016, 06:58 PM   #6
Harley03joe
Re: A/C Dryer ??
I Want To Thank All You Folks For The Answer.
My Next Question Does This 71 Truck Have And Orfice Filter In Line If So Where Is It ?
Harley03joe
Old 07-01-2016, 01:01 AM   #7
Harley03joe
Re: A/C Dryer ??
Does The 1971 Chevrolet C20 Pickup Have An A/C Orifice Tube
Thank You For The Info
Harley03joe
Old 07-01-2016, 01:24 AM   #8
kwmech
Re: A/C Dryer ??
No orifice tube on the 71 if it is still factory. Factory is a POA system.
Old 07-01-2016, 01:06 PM   #9
F.A.A.benny
Re: A/C Dryer ??
If you are going with 134a, recalibrate your poa valve.
F.A.A.benny is offline   Reply With Quote
Old 07-02-2016, 02:22 AM   #10
Harley03joe
Re: A/C Dryer ??
Ok Thanks
Old 07-02-2016, 02:23 AM   #11
Harley03joe
Re: A/C Dryer ??
Question How Do You Recalibrate A POA Valve ???
Thanks For The Answer
Harley03joe
Old 07-10-2016, 04:56 AM   #12
Harley03joe
Re: A/C Dryer ??
I Just Got My New POA Valve 134 From Classic.
After I Evacuate And Pump Down The System, Question Where Do I Hook Up The Wires The Instuction Are Not Real Clear.
The Instructions >>>Replacement for the original POA Valve. Converts the POA System to a Cycling Clutch System like found on most Late Model Vehicles. Saves Gas Milage and decreases length of load on the engine. Easy to install and is compatable with R134 refrigerants.
I Also Replaced The Dryer
And What Should My Gages Read When Full >>> Low 130 >> Hight 230 ?
Also Has And One Used The 134 New POA Valve ?
Thank You For Any Help In This Matter
Harley03joe
Old 07-10-2016, 07:58 AM   #13
Bigdav160
Bigdav160's Avatar
Re: A/C Dryer ??
I don't think many people are happy with the POA eliminator pictured. It turns your system into a cycling system that is normally used with a orifice tube.
Originally, and mostly likely still do, you have an expansion valve as the metering device. It's used with a continuously running compressor.
The POA helped control the pressure in the evaporator core. More modern A/C systems might use an expansion valve without a POA. By adjusting the expansion valve you might be able to get decent performance without the POA. The switch above would then become a protection device
edit to answer your questions.
I do not believe you can buy a "new" POA
The wire on the switch goes in series with the green wire going to your compressor
Google a 134a pressure/temp chart. While running low side pressure should be 35-40 psi.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
