Old 06-30-2016, 11:11 PM   #1
Smokeem
Which of these is correct?
Guys trying to get my truck put back together. When I got the truck it was already torn apart. I've got 2 stepside beds for the truck, and the bed side panels are a little different. The bed that has been stripped has the angles spot welded to the sides and the red bed does not. Which of these is the correct way they are supposed to be.
Smokeem is offline   Reply With Quote
Old 06-30-2016, 11:13 PM   #2
Smokeem
Re: Which of these is correct?
The stripped bedside
Old 07-01-2016, 12:56 AM   #3
swamp rat
swamp rat's Avatar
I cant go look right now but "i think" mine were bolted on.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-01-2016, 08:07 AM   #4
Katrina/10
Katrina/10's Avatar
Originals were all spot welded on.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-01-2016, 08:10 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
Yes, and in your first pic you can see where the spot welds were. You can buy replacement angle pieces now to weld back on.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-01-2016, 08:48 AM   #6
BugzC10
BugzC10's Avatar
As stated, the originals were spot welded on....the angle goes on top of the wood. When I bought my truck I discovered the original angles had been cut off and replace with inverted angles so they could just lay a piece of plywood in the bed. I cut them out and replaced them with bolt-in angles from Mark-K in the correct orientation.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 07-01-2016, 09:05 AM   #7
67ChevyRedneck
Do the bolts go through the side of the bed in areas you can see them, or does their kit only place bolts inside of where the fender is? I guess you could bolt the majority of it and use a couple good spot welds on each end?
Jesse James
Project "On a Dime"
Old 07-01-2016, 09:11 AM   #8
BugzC10
BugzC10's Avatar
Yes...I had to drill all new holes except where the fenders bolted up. I'll post a picture up if I can find one of the bolts going through the the bed side.
Here's a shot where you can see the bolts in the bed side where the old spot welds where.
