06-30-2016, 11:58 AM | #1 |
Where does the cowl vent lead to?
I accidentally pushed some (probably) 40+ year old tree debris in the cowl vent down into the side of the truck somewhere, but I don't know how to get in there to clean it out. Anybody know how to get into there? I just wanted to get an idea before I start tearing everything out looking for something that may be easy to find another way.
1969 Custom C10 |
06-30-2016, 12:00 PM | #2 |
Re: Where does the cowl vent lead to?
You can pull the vent flaps out and reach down in there....the opening goes right beside it and narrows down and goes out the bottom beside the fender.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-30-2016, 12:25 PM | #3 |
Ok, thanks! The vent flap..is that the plastic ball that directs the air flow in the cab?
1969 Custom C10 |
06-30-2016, 12:32 PM | #4 |
The vents are located in the kick panels down by the foot well....an AC truck has a vacuum pot on the passenger side and a slide handle on the drivers side behind the emergency brake pedal bracket.
06-30-2016, 01:00 PM | #5 |
Got it, thanks again!
1969 Custom C10 |
06-30-2016, 05:23 PM | #6 |
get a shop vac and suck all that stuff out. stick a piece of stiff wire or anything handy and stir it up. all kinds of dirt and debris is probably in there causing rust.
06-30-2016, 08:52 PM | #7 |
now the fun begins I have cleaned mine out 3 times put the guard on from lmc I still get crap blowing in whenever I go 55mph or more . but it is getting less
06-30-2016, 09:12 PM | #8 |
When I clean mine out - I use fiberglass screen to keep the debris out moving forward.
https://www.amazon.com/New-York-Wire...erglass+screen I have seen some people hot glue it to the bottom of cowl panel. I went the easy route. I cut two pieces a bit wider than the cowl openings, screwed it down using the factory screws on one side, pulled the other side tight and then used the screws on the other side to hold it tight against the bottom of the cowl. I then use a set of scissors or a box knife to cut off any excess for a clean look. No debris in the cowl and the fiberglass mesh doesn't rust down the road. |
06-30-2016, 09:49 PM | #9 |
Here's how I clean mine out
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-30-2016, 10:17 PM | #10 |
Yes, there is a few poor designs on these old classics, a lot of debris and water traps everywhere
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
07-01-2016, 06:17 AM | #11 |
There is a drain at the bottom. Once you dig all the crap out as best you can, and vacuum, blow air (might want goggles & dust mask). I'd follow up with blasting water to clear all remaining debris. When torn down, I've been known to cut larger holes to allow for better drainage.
07-01-2016, 01:48 PM | #12 |
Thanks for the info guys. Still trying to dig out those flaps. Theyre a little smaller than i thought from the pics. I think ill have my daughter teach in there since the opening is small and the angle makes for a hard grab.
1969 Custom C10 |
07-02-2016, 08:10 AM | #13 |
she's brave... wear latex gloves and watch for mice!
07-02-2016, 12:24 PM | #14 |
When I cleaned mine out, I took the door flap off and scooped out most of it. Then I used a vacuum for the rest and crawled under the truck to clean the drain hole.
07-02-2016, 12:48 PM | #15 |
I stuck a vacuum and air at the same time really helps on stuff blowing out at you.
