Closed Thread
Old 06-29-2016, 07:18 AM   #3926
matthamby
Re: What did you do to your truck today? Chapter II
Sounds like ya'll need to come to NC, mine was less than my 2013 car, also, my grandpa had it registered as a commercial Farm truck, which was much cheaper than it being registered as any other type of vehicle
matthamby is offline
Old 06-29-2016, 02:15 PM   #3927
DarkFlounder
Originally Posted by tdangle View Post
For trucks it's a requirement to have a commercial title. I know in the past you could reregister it as a car but you had to have a camper/camper shell on it. And if you ever took it off even if not hauling something you could get busted.
Basically a way for California to get more money out of you. The reg on my 46 year old truck costs more than my wife's Acura. Go figure.
Not only is my 72 registered as commercial in CA, but I also get hit with the over-weight charge since it's a 3/4 ton.
Well, still, no smog, so it's still worth it.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 06-29-2016, 10:34 PM   #3928
everettelane
everettelane's Avatar
Installed filler panels
everettelane is offline
Old 06-29-2016, 10:35 PM   #3929
Econman
Econman's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
Really, I probably need to buy an engine hoist. The original plan was to lift the engine enough to replace the engine mounts, but then I realized I was taking everything else off the frame..........Ha!....May as well paint the frame right. What you figure the width is on your dolly frame?
If my memory serves me right, I think it was 43". I made it as wide as I could without obstructing anything underneath. The back requires a few 2x4's extra to level it out front to back.
Econman is offline
Old 07-01-2016, 10:10 PM   #3930
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 07-02-2016, 09:02 AM   #3931
RodnRudy
RodnRudy's Avatar
I drove her on her maiden voyage to the local cruise in last eve sans hood. Still have a few odds and ends to finish up in prep for the trip to Louisville for the Street Rod Nationals.
RodnRudy is offline
Old 07-02-2016, 09:49 AM   #3932
66clow
66clow's Avatar
Looks great, what drop do you have? You Buff the original paint?
66clow is offline
Old 07-02-2016, 11:55 AM   #3933
Bomp
Bomp's Avatar
Tore passenger door apart, making new door skin.
Steiner (5" stretch cab)
Ratty skin off.
New skin getting tweaked for fitment.
Drivers side, Reskinned lower part of door and made the rocker.
Bomp is offline
Old 07-02-2016, 02:02 PM   #3934
RodnRudy
RodnRudy's Avatar
For 66clow, The drop is 5/7, 2" drop spindles and 3" drop front springs and 5" drop springs with 2" lowering blocks in the rear. The truck was vermillion red and white top but has a bad repaint a little darker shade. It had been buffed on before I bought it and needs some extra work . I painted the rockers, latch pillars and below rear glass. I'll try to dull that up a little as well as the top.
RodnRudy is offline
Old 07-02-2016, 06:56 PM   #3935
everettelane
Installed new shocks today.
Old 07-02-2016, 10:11 PM   #3936
Possmguts
Possmguts's Avatar
Installed a stall converter, mated the engine and trans, installed new trans pan, Pulled the front clip, Installed the engine and trans, re-installed the front clip and pushed it out side to look at the ride height with weight in it...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 07-02-2016, 10:19 PM   #3937
66clow
66clow's Avatar
Is this an episode of overhaulin? Couple days left for the reveal. nice work.
66clow is offline
Old 07-03-2016, 04:33 AM   #3938
un4gvn!
un4gvn!'s Avatar
Check your upper control arms. There was a thread about being on backwards (right side on left, left side on right) recently. The bump stop is towards the rear. It's a common mistake. You aren't the first and you aren't the last. I just happened to notice in the picture. Just looking out for you.
un4gvn! is offline
Old 07-03-2016, 08:31 AM   #3939
Possmguts
Possmguts's Avatar
Well Hell... I guess I know what Im doing today then... cant believe I did that. Thanks for noticing and giving me a heads up. No telling what that would have driven like and it explains why the wheels looks a little far back in the wheel wells. Thanks again!
Old 07-03-2016, 02:35 PM   #3940
dflarsen77
Active Member
When I bought my truck just recently, the owner said he thinks the carb needs to be rebuilt, the accelerator pump is dead, and if you romp on the gas, it'll stall. Once I knew more about what was going on (replacing the entire fuel system basically), I figured it probably wasn't just the accel pump, but I figured it needed to be replaced anyways, and the carb is pretty old. It's an Edelbrock 1406. Got a kit on eBay from a place called Carb Junkies, good quality kit, came with new floats and an accel pump with a steel rod that supposedly won't be affected by modern gas. Only $43. I've heard these are an easy rebuild, and it really was. Turned this:
into this:
Post cleaning:
Reassembled:
dflarsen77 is offline
Old 07-03-2016, 08:10 PM   #3941
CST10
CST10's Avatar
Added power steering to ol Goldilocks.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 07-03-2016, 08:12 PM   #3942
CST10
CST10's Avatar
Topside photo.
Dam photos are sideways for some reason.
MyToys:
CST10 is offline
Old 07-03-2016, 08:25 PM   #3943
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by CST10 View Post
Topside photo.
Damn!
I had to lay on my back to take a shot of the underside of the P.S. pump...
Damn...!!!!
Hope this helps!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-03-2016, 08:50 PM   #3944
71BUCKET
71BUCKET is offline
Old 07-03-2016, 10:01 PM   #3945
Possmguts
Possmguts's Avatar
Got that corrected first thing this morning... and then moved on to finishing up the front roll pan and fitting the 69 Camaro front spoiler...
Old 07-03-2016, 10:15 PM   #3946
mud.man.rj
mud.man.rj's Avatar
Roll pan and spoiler go great with the super cool hood, getting nothing but better..
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 07-04-2016, 08:46 AM   #3947
CST10
CST10's Avatar
Originally Posted by magwakeenercew2jh View Post
Damn!
Damn...!!!!
Hope this helps!
Thanks. How did you flip em?
MyToys:
CST10 is offline
Old 07-04-2016, 11:13 AM   #3948
magwakeenercew2jh
Trusty iMac.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-04-2016, 11:51 AM   #3949
CST10
CST10's Avatar
Trusty iMac.
Ahhh,
MyToys:
CST10 is offline
Old 07-04-2016, 01:47 PM   #3950
Blakeman350
Blakeman350's Avatar
Well it was more this weekend then today but I did a 5 lug disc brake conversion, change out the gears in the rear end, lowered the front about an inch more and put on a new set of flat black rally wheels.
Blakeman350 is offline
Closed Thread
