Old 06-24-2016, 08:04 PM   #751
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Originally Posted by Grizz1963 View Post
Those are Ultra Cool.
Never even seen them.
Great gift.
Yep they are pretty cool. Turns out that they are from a 73-75 gmc not a 61-63. They have a vey similar look though. Here is what I thought they were
62stepside longbox is offline   Reply With Quote
Old 06-24-2016, 08:06 PM   #752
62stepside longbox
Here is what the ones I got will look like when done. It doesn't bother me, they are close enough and still cool looking
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
Old 06-27-2016, 12:52 AM   #753
62stepside longbox
Wrapped up both of the upper control arms today. New energy suspension bushings, sleeves and balljoint boots. Painted them up too look all pretty. Been having trouble getting lower control arm sleeves out, any tips would be appreciated.
Old 06-27-2016, 12:55 AM   #754
62stepside longbox
Also cleaned up and painted the $15 Swaybar and installed the new moog Swaybar bushings so that when I'm ready to bolt it on its all ready to go.
Old 07-02-2016, 11:29 AM   #755
AJCK87
Hey Nik,
How's the progress coming on the 62?
AJCK87 is offline   Reply With Quote
Old 07-02-2016, 12:35 PM   #756
62stepside longbox
Originally Posted by AJCK87 View Post
Hey Nik,
Hey Anthony, been Getting lots of things done just haven't been posting lately.
The lower control arm sleeves were in ok shape but I had new ones in the kit I bought so I thought "well if I have them might as well use them" and boy they were the most difficult thing I have ever done on my truck. After about 4 hours of hammering and air chiseling I got them to collapse and come out. For the other 3 sleeves left to do I decided to just use the old ones as it wasn't worth the effort to change them
Old 07-02-2016, 12:39 PM   #757
62stepside longbox
And then got the control arm all cleaned up and painted with the one new sleeve in there. Once I finish the other lower control arm I'll get started on pulling the old suspension and putting the new crossmember in
Old 07-02-2016, 01:27 PM   #758
Bomp
Bomp's Avatar
Could you use a press on those?
Bomp is offline   Reply With Quote
Old 07-02-2016, 01:40 PM   #759
62stepside longbox
Not really, there isn't anywhere to press on. If you pressed them they would only go like 1/8" until whatever block or cylinder you're using would hit the control arm. I suppose If you had a cylinder that was exactly 1/16 smaller than the sleeve itself then you could use that with a press but I don't have that or a press
Old 07-03-2016, 11:54 PM   #760
62stepside longbox
Well plans have changed like they usually do, I was trying to avoid pulling the motor and work around it but I decided that it would be best to remove it so I can install the crossmember much easier and it'll give me the opportunity to clean up the engine and make it look pretty with some paint. It's amazing how nice and simple these trucks are, in 30 minutes I had all of this removed, radiator, core support, grille support, grille and all wiring removed. I'll be borrowing a neighbors engine hoist and pulling it out in the next couple days
Old 07-04-2016, 12:37 AM   #761
Ronzo
Ronzo's Avatar
Yeah, probably be glad that you did in the long run. Give you a chance to detail everything and clean it up nice. No offence to the other post comments, but a 4x4 on the fenders sounded like a train wreck in the making to me...
Ronzo is offline   Reply With Quote
Old 07-04-2016, 01:55 AM   #762
62stepside longbox
Yeah I'm sure pulling the motor will be worth it, everything will look nice and pretty after. That method with putting weight on the fenders did indeed sound like a train wreck, I don't even think evel knievel would try a stunt like that, Well you never know...
Old 07-04-2016, 09:51 AM   #763
TJ's Chevy
TJ's Chevy's Avatar
Lotta work ahead...better get to work buddy! lol! Looking good! Man....while that 6 banger is out I'd be replacing gaskets and giving it a chevy 6 blue paint job. Maybe even order me a set of fenton headers and offy dual intake.
Old 07-04-2016, 11:27 AM   #764
62stepside longbox
Yep I plan to get it out sometime this week, I don't know about Fenton and offy (I'm a bit too cheap) but it'll definitely get a clean up and some nice blue paint , Tj I know you have removed at least one straight six, do you mind giving me some tips on say where to attach the chain to the block when lifting it out. Thanks
Old 07-04-2016, 12:16 PM   #765
TJ's Chevy
TJ's Chevy's Avatar
I pulled the engine and tranny as one piece so it might make things a bit different. I cradled the back with a chain and then bolted a chain on the side of the motor where the A/C brackets would go. The 235's don't have those holes there that I am aware of. Another thing I did was wrap chains around the motor mounts. Hey....62 Barnfind would know lots about pulling 235's!
Old 07-05-2016, 11:05 PM   #766
62stepside longbox
Thanks for the advice Tj, I talked to John on the phone today for a while and he gave me some tips. First I removed everything that was needed such as driveshaft, shifter, hydraulic clutch lines etc. Then I built some L brackets that attach to the head bolts.
Old 07-05-2016, 11:06 PM   #767
62stepside longbox
And she's out!
Old 07-05-2016, 11:09 PM   #768
62stepside longbox
Tomorrow I'll start cleaning all of the dirt and grease off and getting it prepped for paint. I'm thinking the original alpine green
Old 07-06-2016, 12:09 AM   #769
TJ's Chevy
TJ's Chevy's Avatar
Cool! Glad John was able to help.
Old 07-06-2016, 01:13 AM   #770
Grizz1963
Grizz1963's Avatar
Original is a great colour.
I would vote for it, but of course it is your truck, so your choice.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-06-2016, 03:03 AM   #771
62stepside longbox
Yeah that's why this forum is so great buddy!
I definitely do want to go with the original colour but that's only if I can find it in high heat
Old 07-06-2016, 07:08 AM   #772
Nice!
Old 07-06-2016, 09:17 AM   #773
62 Barnfind
62 Barnfind's Avatar
Glad you got it out! The green is going to make that engine stand out. Get ready for a bunch so scraping and cleaning. It's all in the prep work!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 07-06-2016, 04:21 PM   #774
62stepside longbox
Nice!
Thanks bill
Thanks John, yep the alpine green will look good I just need to find it in high heat
Old 07-06-2016, 04:23 PM   #775
62stepside longbox
Decided to try some buffing on the original paint on the firewall. Here is before
