Old 06-30-2016, 01:44 PM   #1
ryans69chevy
Trailing arm bushings
I can't seem to get these out. First I tried using a hammer then I drilled out the rubber and got the inner sleeve with rubber out, but couldn't get the outer sleeve out so I took a saw zal and cut it in half which I now think was a bad idea... With the other trailing arm I went and rented a ball joint press and could only get the inner sleeve 3/4 out cuz it would hit part of the clamp.
I've read on here that people use these all the time. So what am I doing wrong??... I know I could just take these into a shop and pay to get them replaced, but I enjoy doing this stuff on my own and figuring it out, but I can't seem to figure this out!
Thanks,
Ryan
ryans69chevy is offline   Reply With Quote
Old 06-30-2016, 01:46 PM   #2
ryans69chevy
Re: Trailing arm bushings
Here is the typical c clamp style ball joint remover. The sleeves I have for it are just a touch too big. They cover the outside of the hole.
Old 06-30-2016, 02:31 PM   #3
Oldblue68chevy
I used a little heat from my torch and the rubber insert pretty much pops right out. I put urethane bushings in mine and I think I you need to leave that outer bushing in place.I would think heat will help remove that as well. If you already have the rubber out you may be able to crush the sleeve and get it out that way too.
Oldblue68chevy is offline   Reply With Quote
Old 06-30-2016, 03:29 PM   #4
summitflier
summitflier's Avatar
I just went the drill route. Drilled about a dozen holes all around the metal core.
I replaced the inner metal sleeves, so I didn't care if they got boogered up.
Also I put a little wheel bearing grease on the new ones to get them in.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 06-30-2016, 04:26 PM   #5
ryans69chevy
I purchased new rubber bushings so they come with the inner and outer sleeves so I need to remove my existing outer sleeves...
Old 06-30-2016, 04:42 PM   #6
Rich69shortfleet
You have to press on the outer shell, not just the inner shell.
But, since you've already got the guts out, just take a chisel and a big hammer and collapse the outer shell. When you press them in, first put the bushings in the freezer overnight and then press them in by pushing on the outer shell. If you are lucky, they will go in with just a few taps from a hammer. They will tighten up when they warm up to the same temp as the arm.
Rich69shortfleet is offline   Reply With Quote
Old 06-30-2016, 06:49 PM   #7
Shady Rascal
Shady Rascal's Avatar
I use a pretty sadistic air hammer to fold the outer shells inward. Once you get one spot pushed in and the bushing shell is no longer a circle, they all but fall out. You can buy a real righteous air hammer for 100 bucks.
Shady Rascal is offline   Reply With Quote
Old 06-30-2016, 07:30 PM   #8
ryans69chevy
Alrighty I will try the chisel with a hammer! Air hammer sounds nice, but I don't air... Yet! Thanks!
Old 06-30-2016, 07:50 PM   #9
NC_John
NC_John's Avatar
Get a torch, propane or a/o, and burn them out. It'll make a lot of smoke but works like a champ.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 06-30-2016, 07:54 PM   #10
everettelane
everettelane's Avatar
I went to oreilly's and picked up this tail pipe adapter 2 1/2" then went to local hardware store and picked up a 1" conduit coupling rigid galvanized and 3 lb hammer laid the trailing arm bushing over the tailpipe adapter and drove out the bushing with coupling worked like a champ about three hits it fell out.
everettelane is offline   Reply With Quote
Old 06-30-2016, 08:36 PM   #11
jjlett69
jjlett69's Avatar
I just set mine on fire and let em burn , and they tapped out with no effort once 75% of bushing melted away.
John
San Diego, CA
1969 C-10
“ A person who never made a mistake, never tried anything new.” Albert Einstein
jjlett69 is offline   Reply With Quote
Old 06-30-2016, 08:38 PM   #12
Shady Rascal
All the recommendations of using a torch are not gonna help this guy. He's trying to remove the outer steel shell part of the bushing.
Old 06-30-2016, 09:37 PM   #13
88Ironduke
I'm picking up what jjlet69 is putting down. Burn out the old bushings, with the rubber bushing out of the way removing the outer shell is a snap. Especially when the tools to get the job the "correct way" are not available. I've done it both ways and both methods are effective. And it sounds the OP doesn't have all the goodies on hand to get the job done without a little creativity. Burn'em out, pound out whats left via punches and large screw drivers. Press in new bushing sets.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 07-04-2016, 12:30 PM   #14
ryans69chevy
Well I got them out! Had to be a little creative! I'll try and explain the best way I can as to how I got them out so ppl in the future with this problem might get some ideas.
First from where I left off one of my inner bushings was almost out. It kept hitting the c clamp so I tried the torch which took a longgggggggg time and still was a pain. I finally just took my saw zal and cut the excess off and used the ball joint c clamp again and pressed it on out!
Now I just have to remove the outer sleeve so first I cut the outer sleeve in half. I did this so it would be start moving easier. I then found that my 27mm impact socket fits the diameter of the outer sleeve.
Old 07-04-2016, 12:35 PM   #15
ryans69chevy
Then I used the socket as an adapter for the ball joint press and began pressing out the non flanged side which pushes the flanged side out a little bit. Now I used a pry bar to get under the flange so I could remove that side.
Old 07-04-2016, 12:40 PM   #16
ryans69chevy
Now I just had to remove the non flanged side which turned out to be pretty easy. This is the basics of how I did it. Hope you can see it alright in the pic. I used my socket again that slid right into the trailing arm.
Old 07-04-2016, 12:47 PM   #17
ryans69chevy
I was having trouble with the socket not staying straight so I grabbed a piece of 1/2" plywood to stick in between so it would apply more equal pressure. This method worked for me. It was a lot of steps, but they came out. It was cheaper than taking it into a shop. I will try and post a pic of how they go in. I will most likely try the freezer trick that was mentioned. I won't be able to throw them in for another week or so since I took the arms into a welding shop to have the flanges straightened out a bit. My little hand torch couldn't get the metal hot enough.
